modifying the D1 I/V stage (X?, CCS?)
Retired diyAudio Moderator
Joined 2002
Has anyone tried modifying the D1 I/V stage? I am wondering if it would sonically benefit if it was converted to an X type setup.
Also, what about using current sources?
Here is a picture of the stage from the service manual:
( http://www.passlabs.com/pdf/d1-srv-man.pdf )
Brian
conversion to 0,1mA DAC?
I have also released a question about converting the D1 stage, maybe in the wrong forum part, because just one answers has come so far...
The essence of the tread below is: how to use the 0,1mA I-output of TDA1547 with a changed D1-stage? My idea is the reducing of bias current to ca. 1mA and use of a smaller FET like e.g. 2SK389. Is there any mistake in this realization? Thanks for feedback!
http://www.diyaudio.com/forums/showthread.php?threadid=19751
Klaus
The one and only
Joined 2001
It seems that current output DACs are designed to
ideally operate into virtual grounds.
As the transconductance of the JFET in question goes
down, more signal voltage will appear at the source,
and any dependence of signal quality vs output voltage
of the DAC will start showing up.
That said, I would expect it to work fine.
Hi Klaus,
I want to upgrade my Marantz CD 16 with the 1547 inside as well. So, I would be extremly interested to understand if you succeed in combining a 1547 with Nelson's D1-stage and basiscally what the final schematic was / how you connected it to the 1547.
Thanks & Best Regards
Ouput Cap ?
I would like as well to ask the same question as promitheus: Why is the Output cap so large ?
Which impedance does it see ? If it sees the 22K only, than 1 uF would be sufficient. If it sees only the 150 R, 212uF would be required for 5 Hz. Sorry, that's a newbie question, but before I start to spend long time with books, I want to ask the designer pros here.
Anyway, I would prefer to understand how I could get rid of the cap anyway ?
