in fact, it is not necessary
I tried and it's all the same ............. unless in case that your amp is really scorched, needing any help, badly
(which reminds me ........... post #126, Babelfish XA252 / Babelfish XA252 SIT / Babelfish XA252 SET )
is there a need to say that platform feet doesn't need to be so high ?
inch or so is more than enough
but, if you like them that way -
At least two inches, with the fan not embedded in the wooden board
By the way I'll put a DAC downside.
@Cody: 12cm computer fan for cabinet. Sleeve bearing type. 12Vdc with a simple SMPS
- Babysitter for Papa's Koan
