F5 Cascoded - an alternative for my interest in the Balanced F5 - Page 2 - diyAudio
Old 22nd January 2011, 10:58 AM   #11
juma is offline juma  Germany
juma's Avatar
@NYCOne
I look at your PCB in post #1 and it's a bit crowded with 150R/3W feedback resistors.
I planned that PCB for 3x150R/2W feedback resistors since I can't buy locally 100R/3W ones.
You can use 2x100R/3W to avoid crowding.
Old 22nd January 2011, 11:59 AM   #12
Zen Mod is online now Zen Mod  Serbia
Zen Mod's Avatar
boyz
Papa meant on small cascoding bjt's , not on outputs
he gave another important tip - keep strong and firm biasing of them
you already have that in those posted schematics , all over variouss F5 threads
sabath - I meant on wattage of feedback resistors , in case of max PSU voltage
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 22nd January 2011, 12:46 PM   #13
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
I deleted my post, to avoid further confusion
Old 22nd January 2011, 02:09 PM   #14
I've also been following the balanced F-5 thread with much interest. Previously, I had been interested in some posts of F-5 with more power and ideas for doing it, where cascode, multiple outputs, etc were discussed.
Cascoding very much interested me, both for the F-5 as well the BA-2. Cascoding questions seemed to be a little above my understanding, so I decided to sit back, read other threads on the topic and see what I could learn. Thanks for posting this, I'm still very intersted in the balanced F-5, but this thread will hopefully be the one the clears up the cascoding process up.
Meanwhile, I play the F-5 in a system where the gain is adequate, and am happy. The F-5 is what it is, and is exceptional as that. While my first reaction was, "Wow, I should would like this in a high power version" I dont know that the result would be as enjoyable. Many times with commercial amps, I've noticed that when there is a 60 watt version, a 100 watt version and a 200 watt version, the less powerful version seems to sound the best....within its power range. Similarly I fear that higher power/gain versions wont have the same magic.
Hopefully this thread will not only be an in general learning experience for me, but will also allow me to understand cascoding, so thanks!
Russellc
Old 22nd January 2011, 02:50 PM   #15
flg is offline flg  United States
flg's Avatar
http://www.passlabs.com/pdfs/articles/cascode.pdf
"It was the perfect high end audio product: Exotic, inefficient, expensive, unavailable, and toxic." N.P.
Old 22nd January 2011, 03:56 PM   #16
The one and only
Nelson Pass's Avatar
Originally Posted by NYCOne View Post
I'm not sure I follow the "caps to ground" - I have the caps where your diagram suggests. I can change this if I misinterpreted your figure.
That would be the "fewer parts" edition. The cap from
base to base achieves much the same thing as the base
currents cancel each other.
This is a bandwidth issue, the object being to prevent
the cascodes from degrading the bandwidth due to high
impedances on their bases.
Old 22nd January 2011, 04:14 PM   #17
Banned
Tanks Zen
realy apreciated
As NICOne say (quote what time is it ......
Hope ranting and rawing bout (well how shuld I put this...) is over
Nycone yust did it again you started a briliant tread mate.
Be back in a Jffy got a pcb IDEA to share
Old 22nd January 2011, 04:24 PM   #18
Originally Posted by flg View Post
Thanks, always enjoy info on Pass. I've read that one from someone else's recommendation. Nice read, but didnt leave me in a place to be able to implement as I am inexperienced in design. I can follow the idea, I can identify parts and am fairly good with a soldering Iron. I follow directions well, I just am no where near taking an idea like cascoding and applying it to an existing amplifier without guidance.
Thanks for the comments,
much appreciated,
Russellc
Old 22nd January 2011, 04:36 PM   #19
Banned
F5 PCB triple (reminding me of last time I left a bike under a buss)
Ernos cascode in this version.
Old 22nd January 2011, 04:38 PM   #20
Banned
Ta DAA
(where diid I steal this?)
Balanced F5 triple
Balanced F5 question NYCOne Pass Labs 1153 23rd February 2011 07:42 PM
F5 Williams Audio Pass Labs 9 11th June 2010 10:13 PM
I need Help with my F5.... rtate Pass Labs 15 2nd December 2009 12:07 AM
Anybody help with F5? yammy1688 Pass Labs 2 28th October 2008 04:50 PM
Yet another variation on cascoded balanced line stage jwb Pass Labs 10 27th October 2002 06:22 PM
Copyright 1999-2017 diyAudio
