Old 26th February 2013, 05:57 PM   #1651
Bernt is offline Bernt  Sweden
Oh, the sound! Sorry, forgot to describe it. It is extremely relaxed and easy, natural and very, very dynamic.Excellent midbass! The only difficulty is that the output impedance is a little on the high side so the bass is a little bit swollen on my speakers. (TQWP with 15 inch coax, Beyma 15xa38nd) I solved this by putting a 20 ohm resistor between the speaker terminals to even out the impedance a little. I get about 2x30W to the speakers and 300W heat to the water.
I have built several tube amps including OTLs but this one beats them all.
Compared today with a F5 and it is a matter of taste what you prefer, I see no reason to swap. If one is listening for hours on end I think the SoZ wins really.
The cables are long, about 6 meters each way to the speakers plus the leads between the power supply and the cooler. No problem with that though.
Old 26th February 2013, 06:17 PM   #1652
udailey is offline udailey  United States
Passive Aggressive
I would check your water pipes and make sure they are grounded.
You can purchase LDRs anytime to build a standard LDR attenuator or to build my new LDR Attenuator "A Lighter Note". Email me. diyldr@gmail.com
Old 26th February 2013, 06:23 PM   #1653
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
Originally Posted by oneplustwo View Post
any ill effects
Not an issue an a horse and carriage amp.
Not so much,.......if it says "ZM" in the corner.
Old 26th February 2013, 08:55 PM   #1654
bcmbob is offline bcmbob  United States
Since we are on the subject, the next version of the BLAT is nearing completion. Instead of folding the earlier design I decided to eliminate the small U channel and screws, and move to a piece of standard heat sink. Blind holes were used wherever possible to reduce possible leaks around screws.
I'll post a breakout of the components in a day or so (most likely over on the BLAT thread) but it's basically HS, paper automotive head gasket material, aluminum plate, plexiglass plate (used only temporarily to check flow pattern) and some threaded 6-32 rod. Essentially, the liquid flows through the bottom two slots all the way to the back. In addition to passage holes in the back interior, there is a small gap between the HS halves that facilitates the flow. The top two channels (sealed from all others) collect the liquid - again at the back - and present it to the top fitting.
The pump will most likely stay the same (smaller than the previous one but just as powerful) but I still want to reduce the size of the radiator/fan combo. The final configuration - be it horizontal or vertical - will have the operating components of the cooling system below the amps for safety.
There is a BLAT 3 which is smaller and thinner, more suited to the F5 clone boards at the diyAudio store, that won't be finished till the weekend.
Edit: This version is 11.5" X 1.5" X 4.8"
Bob M.
"Arrange Whatever Pieces Come Your Way."
Old 26th February 2013, 10:55 PM   #1655
Here's short clip of the action. To see the actual flow rate watch the short tube in the upper left corner as soon as the color is added. There is a lot of mixing inside both the radiator and the cooler itself, but the rate is steady. Will need to adjust flow rate and fan speed to get the best heat transfer.
BLAT 2 Flow Clip (click play on video)
Bob M.
Old 26th February 2013, 11:32 PM   #1656
How loud is the entire setup? Those pumps used to be quite noisy! The fans won't help either!
Old 26th February 2013, 11:36 PM   #1657
a.wayne is offline a.wayne  United States
a.wayne's Avatar
Sweeeet , much better than the simplicity of fans .....
A man should look for what is, and not for what he thinks should be. -Albert Einstein
Old 26th February 2013, 11:48 PM   #1658
The new breed of pumps are silent with almost any type of foam padding underneath. What can be heard is a light vibration if there is any direct physical contact with wood or metal that can amplify it. Again, a small foam pad eliminates that.
The fans are a bigger problem but that is just the sound of the air flow. I believe a final build with the fans pointing away from the listening position will solve that. You have to be within 2 - 3 feet to know it's running. There is a great brand "Loon" that has a 120 mm unit that is really silent. I have two of them in the PC at my feet and they can not be heard. They are low speed and will require a single 120 radiator instead of the dual 80s. I'm working on it.
Thanks a.wayne
Bob M.
Old 27th February 2013, 01:24 AM   #1659
Sorry, I was trying to remove the ranting in the background and broke the link to the video.
Here it is again.
BLAT 2 Flow Cliphttps://www.box.com/s/9jxs7c91w2q63ptqbynp
Bob M.
Old 27th February 2013, 07:08 AM   #1660
regiregi22's Avatar
Bernt,
Awesome idea! How do you manage to use the amplifier while the heating system is turned off in summer?
As a silent PC fan, I can recommend you this website where they compare, among other computer part, silent fans. I have used (and actually use) Noctua and Nexus fans. I think Yate Loon makes those Nexus. They have measured the noise on each one:
Recommended Fans | silentpcreview.com
diyAudio, doing it as big as you can, JUST BECAUSE WE CAN!
DIY Low Pass and Mid/High Pass (Bass Blocking) Filters runslikealpaca Everything Else 1 19th June 2009 10:59 PM
Naked pictures of Pass Pete Fleming Pass Labs 30 9th December 2006 06:39 AM
My new hifi amplifier (pictures) Wejp Chip Amps 23 15th October 2004 12:16 AM
Pass Diy High Low Pass Please macka Pass Labs 127 2nd March 2004 11:00 PM
DIY Pass labs 100watt amplifier. microwalsh8504 Pass Labs 12 6th February 2004 07:27 PM
Copyright ©1999-2013 diyAudio
