BF862 Preamp
BF862 Preamp
Old 9th December 2017, 01:57 PM   #541
xrk971 is online now xrk971  United States
Got Foam?
xrk971's Avatar
BF862 Preamp
Update to the above Aksa Lender pre FFT, when implemented in real PCB as designed by JPS64, distortion went down to below 0.001% THD.
XRKaudio https://www.etsy.com/shop/XRKAudio
Old 11th December 2017, 07:43 AM   #542
sarathssca is offline sarathssca  India
1. Do we need the single BF862 in gain stage to be matching with the one in the other channel of the stereo preamp?
2. For getting 4 matched BF862 for the buffer stage, approx how many BF862s we need to procure and do test matching?
3. Why are we using asymmetric power supply here ie positive and negative rails of different voltages, unlike more commonly used +/-10v or +/-12v (where both +ive and -ive rails have same voltage with opposite polarity)?
Old 11th December 2017, 08:56 AM   #543
R.I.P.
I bought 600 lsk170.
I found many matched twins, in various grades of matching accuracy from 0.25% to 5%.
I did not find any quads.
BTW, that is matching over a range of Id, not selecting by measuring Idss.
regards Andrew T.
Old 11th December 2017, 11:22 AM   #544
juma is offline juma  Germany
juma's Avatar
1. Yes
2. In 500 pcs. of BF862 I have bought at Mouser almost all have the Idss in range of 13-14mA so matches were abundant in that quantity (all JFETs delivered to me were on the same production stripe). Others have different experiences.
3. Already explained - please read the thread from the beginning. Actually, you can do it without negative rail - see post #346. The price to be payed is introduction of input coupling cap.
Please don't use private messages for question related to audio projects. It defeats the purpose of the forum.
Old 12th December 2017, 12:54 PM   #545
Got Foam?
xrk971's Avatar
BF862 Preamp
I made a small quick and dirty mockup of the actual circuit the BF862 will be used in and then measured the current through a 1k drain resistor (part of actual circuit) at the voltage it will be used at (16.4v) and can get pretty amount of pairs (40%) with better than 1%. Trick is to push down on JFET with enough force to make contact yet not make it fly off with a pop. The eraser of a pencil is good for this.
Old 15th January 2018, 12:51 PM   #546
veloplex is offline veloplex  Germany
Hi XRK971,
could you drop the shematic of your "mockup" please? You messure the Idss current through/over the 1k drain resistor?
Christoph
BF862 PreampHide this!Advertise here!
Tube Preamp Popping on Source Input Change (?) / 6DJ8 Preamp On Chip Amps Travis Clarke Tubes / Valves 3 16th October 2008 04:52 AM
twisted pear Preamp/other suggestions for Preamp kit LukeDuke Chip Amps 1 1st February 2008 09:57 PM
Electret mic preamp - will phono preamp work? darthmullet Analogue Source 6 12th October 2007 07:32 AM
wiring preamp outs on a preamp bonsai171 Solid State 4 22nd March 2004 10:13 PM
