Old 4th June 2009, 03:32 PM   #1
Default The 50W version of Zen9
I just have finished building of one monoblock of 50W Zen9 (4,8A quiescent current) and plan to share some experience and impressions.
Old 4th June 2009, 05:29 PM   #2
flg is offline flg  United States
flg's Avatar
I have eperimented towards that goal Please, would you share with us your approach(s) etc.
I've tried higher I, L loads in place of Aleph (not exactly ZV9 ) R loads in place of Aleph(ditto), dual cascoded JFETs, dual JFETs and one cascode MOSFET...
It has lead to some other (Off Thread ideas) but at this moment, for the initial "real" build, I have a B3(Peter D.) board stuffed w/some premo Vishay, Caddock, Holcro and elna/RelCap parts ??? ready to mount to more than enough Heat Sink and a 47V, 10A supply. I also have components for a 55V supply (probably the most promising improvement).
I just expected N.P. to give us a few Bread Crumbs of what he has in mind for the " more powerfull version" of That design???
I expect I will eventually use my ZV9/B3 amp on the top side of a Bi-Amped system driving my Ri Ribbon HF units. They are a little low in Impeadance/Resistance so that is most of the reason for eperimenting...
“Be who you are and say what you feel because those who mind don't matter and those who matter don't mind.” Dr. Seuss
Old 4th June 2009, 08:34 PM   #3
The one and only
Nelson Pass's Avatar
OK, here's a little crouton for you:
More Current and More Voltage.
Old 5th June 2009, 12:45 PM   #4
Before the 4,8A version of Zen9 I built both Zen4 and Zen9 with “ordinary” quiescent current 2,8A, and was not quite satisfied with the bass from my Paradigm Studio 100 v4 loudspeakers. Exploring information about amplifier-loudspeaker interaction made clear that not only absolute value of speaker impedance Z, but also phase angle affect the peak current demand from power amp. That is, if the lowest Paradigm’s impedance is 3 Ohm at 80Hz, and the phase is not zero at this point, than the peak current consumption for 20V signal at 80Hz will be more than 7A. This is the first reason why I have tried 4,8A quiescent current. Second, achieving this current is easiest just with Zen9, since one must not trouble about driving of multi-transistor output stage.
In order to feel myself safe with the elevated heat dissipation, I have employed 4 + 4 pcs of the laterals 2SK1058 (Q2 and Q3). Power supply voltage at the drain of Q4 (IRFP140N, schematics as in the Zen9 article by Nelson) is 54V, and 48V at the source of Q4. Q1 is LD1010DA unsoldered from the old computer motherboard. All transistors are mounted on ceramic pads (TO-3 form) that acts as electric insulators and quite good heat dissipators. Shottky diods also help to improve the bass, as well as 1 kW trafo (48v secondary) and LC-LC supply filter (0,5mH-50mF-1,5mH-60mF). Power supply is an external unit.
As of C1, I have used 35 pcs of Low-ESR Jamicon WG 680 microF x 63V, C2 and C6 are 30 microF Polypropylene capacitors.
Now I have tested and listened to one channel only (mono). Sound is the best of all my previous listenings. Hope to finish the second channel soon.
Old 5th June 2009, 10:48 PM   #5
Magura is offline Magura  Denmark
Magura's Avatar
That's the right spirit...love you attitude!
Magura
Everything is possible....to do the impossible just takes a little while longer.
www.class-a-labs.com
Old 8th June 2009, 02:10 PM   #6
Now I have the second external power supply ready for Zen9 4,8A monoblocks. I have connected them to my old Zen4 2,8A monoblocks, and was surprized a little bit with bass improvement from Zen4. Previous Zen4 power supplies contain 400W toroids and ordinary diods bridge (shunted with 0,1microF film capacitors). The Zen4 bass is still not as good as from Zen9 4,8A, but the difference is hardly distinguishable. It is hard to point out main reason, but, empirically, for 20-30W Zens and FirstWatt Fs power supply with 1kW toroid per channel and Shottky diods bridge can be recommended. Another plus from a big toproid is that it is completely silent at underloaded operation conditions.
I have also measured output impedances of both amps at 1 kHz. They are 0,9 Ohm and 1,4 Ohm for Zen9 and Zen4, respectively.
Old 9th June 2009, 02:23 PM   #7
Main assembling features of the Zen9 4,8A monoblocks – point-to-point soldering on 3mm PTFE board and multi-capacitor assembling of C1. All my efforts to achieve transparent sound with various 4700-22000 microF capacitors as C1 had no success (C7 shunt capacitor always 30 microF polypropylene). I hope somebody else will try and report his impressions from the multi-capacitor solution for C1 in Zen4 or Zen9 schematics. Even the wiring inductance of multi-capacitor assembling gives almost no negative effect as compared to drastic increase in sound transparency. Also one must especially care about C9 quality, since it sits in signal path.
Speaking about listening impressions one must also describe his complete system. My system components are:
Shanling CD-T1500 CD-player
Parasound JC2 Preamp
Zen9 or Zen 4 power amps
Paradigm Studio 100 v.4 speakers
Stereovox LSP-600c speaker cable (2m)
Nordost Blue Heaven interconnect cable (1,5m) XLR
Nordost Blue Heaven interconnect cable (1,5m) RCA
BlackNoise line filter
In this system I feel the speakers are a weak point, but system is OK to feel differences between various cables and other components.
Old 9th June 2009, 05:37 PM   #8
You could try a biased bipolar for C1. 2 pair of 10,000uf 50v caps in seriese ( + -- + ) so you get a 100v 10,000uf bipolar cap then connect the center - terminal to ~ -20v through a high resistance. I have used a biased bipolar in another aplication where it realy made a big difference.
Old 10th June 2009, 05:55 AM   #9
Interesting idea, but it requires additional supply rail. Did you try the proposed solution in a power amp? You are saying about big positive effect in another application, but, in many cases, when we feel sound improvement, we can not point out definite measurable parameter responsible for that improvement. Do you have any guess what could be a reason for the positive effect?
As for the multi-small-capacitor solution, I explained the positive effect by better relative mechanical rigidity of the internal structure of smaller electrolytic capacitors compared to big ones. Currents of the order of several amperes through a big electrolyte quite possibly can cause electro-mechanical effects that modulate and smear high frequencies.
Old 10th June 2009, 08:22 AM   #10
For schematics with elevated quiescent current, like for instance 4,8A, some cautions must be put to power supply design. Enclosed is a result of simulation of C1-L-C2 filter loaded by 4,8A constant current source. Other values are visible from the picture. Time dependences of currents through C1 and C2 are shown. Important is that RMS current through C1 consists 8,5A, while through C2 it is 0,1A only. So, one must care not only about the most important big C2 value, but possibilities of C1 as for acceptable ripple current must not be violated.
File Type: jpg power supply filter currents_resize.jpg (83.2 KB, 2143 views)
Zen Version 4 R10 skidave Pass Labs 1 8th March 2007 06:52 PM
Zen9 and Jordan jx92s cascadeguy Pass Labs 7 14th January 2007 12:27 AM
Zen Version 4 skidave Pass Labs 1 19th December 2006 06:36 AM
JLH (my version) bogdan_borko Solid State 4 25th November 2006 08:58 AM
replace C-multiplier in ZEN9? kekso22 Pass Labs 6 8th March 2006 05:19 PM
Page generated in 0.17447 seconds (71.12% PHP - 28.88% MySQL) with 11 queries
