#1801 |
diyAudio Chief Moderator
Any stable DC source, its only a utility. Get a 2SK170 low IDSS, 2N5459 ,or any other 5-6mA IDSS NJFET, connect its drain at B(+), connect its G&S together, crock lead LED's anode there too. Return cathode to (-). Measure Vf across lit LED. Stick it on paper, note its Vf. Repeat for some. Do the sorting later picking from the noted bunch. Alternative and more precise to a resistor.
#1802 |
Thanks Salas,
I was just wondering about the method, stable DC source. I've done the matching 3 times, very close measures. I'll try to match 2SK170 too ![]() Schematic here : Transistor matching |
#1803 |
Just that is enough. Let the fets stabilize for 3 mins, and watch not to short the dvm, it will blow a fuse.
#1804 |
Thank you for the advices !
#1805 |
2SK170BL Matching session today about 100 units.
Results using the previous posted link schema : 6.51/6.52 - 6.61/6.62 - 6.67/6.67 - 6.95/6.96 7.11/7.12/7.13 - 7.17/7.18 - 7.26/7.27 - 7.39/7.39 - 7.48/7.49 - 7.65/7.65 - 7.94/7.94 8.16/8.16/8.16 - 8.49/8.49 - 8.81/8.81 - 8.83/8.83 - 8.96/8.97 9.93/9.94 10.91/10.92 About 18 pairs/trio found. Question Which of them should I prefer using in Q1/2 and Q3/4 position as shown in this pic ? Thanks
#1806 |
7.12/7.11 - 7.17/7.18 1,2,3,4
#1807 |
Thank you Salas
It will equilibrate the values in this order Q1:7.12/Q3:7.17 and Q2:7.11/Q4:7.18 Am I right ? |
#1808 |
No, fit just as I gave the order.
#1809 |
Yes Sir !
#1810 |
At ease!
| New-building of my B1 buffer | Babowana | Pass Labs | 328 | 20th February 2010 01:14 AM |
