Paper mache horn fabricator
I'm playing with something simple; sim says it works. Looking for advice.
I enjoy audio so much that I constructed a web site. I share my ideas at: www.inlowsound.com |
#2 |
How did you set the bias ?
Tyimo |
#3 |
It runs full out but doesn't seem to get enough current to blow it up... the resistance of the choke is 0.4 ohms.
Oddest thing I've ever played around with.
#4 |
Hi John, Happy Holiday's
I've been thinking about a LU1014 diff version lately too My ideas are more like a SOZJ with lower CCs and 7000W water heater elements(8 ohm) for a Resistive load. Playing with the "1 ohm" cross coupling resister gives interesting results. Havent totally figured out the details yet...
“Be who you are and say what you feel because those who mind don't matter and those who matter don't mind.” Dr. Seuss |
#5 |
The one and only
Very cool. Convenient that the coils have that 0.4 ohms...
#6 | |
0R4 for 200mH, is that something you just found in spice, or are they for real? Magura
Everything is possible....to do the impossible just takes a little while longer. www.class-a-labs.com |
#7 | ||
Hi flg. The voltmeter wanders (kinda like my brain) between 0.3 through 0.6. ohms. So, I'm in the ballpark. Also, I was thinking that a slightly smaller transformer will probably yield a stronger output since it has less resistance. What a blast. I can order a regulated 6 volt power supply for somewhere in the neighborhood of 55 bucks. This little fellow has no tolerance for voltage variation. Regulated 5 volt units are plentiful as well--the amp delivers less wattage, but gets the diff voltage between the legs of the jfet closer to the desired triode state. It's interesting to note that other members ride the same wavelength at the same time... Universal consciousness?
#8 | |
is that just fact that English is not my native language , or I simply don't understand that sentence ...
my Papa is smarter than your Nelson ! tnx to |
#9 |
The way this amp is laid out, the LU1014 runs more voltage than current compared against the triode curve on the LU1014 VDS graph: the sim states 5.4 volt diff with 1.6 amps--the graph curves asks for 8 or 9 amps at this voltage diff. My question to anyone who has an understanding of triode characteristics is this: will the amp sound sweeter, or simply more distorted when running less current than the curve requires?
#10 | |
Magura likes to warm his house in class A mode.
| Differential to differential amplifier | Cauhtemoc | Solid State | 3 | 15th August 2007 07:39 AM |
| differential amplifier | Thomas Giz | Digital Source | 1 | 23rd March 2003 08:07 PM |
| Aleph OPS as a differential amplifier. Possible? | blschuler | Pass Labs | 11 | 26th January 2002 04:50 PM |
| Page generated in 0.10299 seconds (80.80% PHP - 19.20% MySQL) with 11 queries |
