B1 Buffer Preamp
R1 is part of the CRC-filter to reduce ripple of the power supply. Do a search on CRC, a very popular method for ClassA amps.
The B1 has decent PSRR since the jfet is fed by a (jfet) current source, so using a regulator probably brings little benefit. Of course feel free to experiment 😀
Have fun, Hannes
You can use this one too. Plays good tunes for my NJFET RIAA. Noise floor very low.
Compact enough, just warm, won't oscillate easily, readily available Mosfets, leftover unmatched SK170s. Iccs = (Vleds-3.4)/R1 (1W resistor). Start with 10R. Led string of 3 gives different Vdrop total depending on color and maker. Use green ones, more constant. I wanted it ''Kitsch LED Shunt'' so I used tricolore.😀
Haven't made a negative side. My Riaa is positive only, B1 is positive only with caps, you want to make a capacitor-less one with symmetrical PSUs like I did? I can try to mirror it on the simulator if so.
Neg reg
That would be nice, if you don't mind Salas.
Instead of the B1, I use a "JC" buffer (k170, j74) like NP's, in the Lightspeed Vol Control for my F3 and headamp (DOA-T) - both have low input Z.
It's nearly totally transparent but is very dependent on the supply - using a "rough" Toole shunt reg at present, and curious to hear the sound of yours, and also in comparison to the "Teddy-reg".
I've got a couple of quick questions. I'm got a few more parts to order, but I've got some 'spare' parts I could try.
I've got 100k Stereo pot, and a 100k stepped attenuator from a previous project. I guess I could substitute them in for a while.
What's the best way to scope and test this buffer?
I've got an oscilloscope I haven't used in years, hopefully it still works.
Re: Neg reg
OK, I posted negatives. If you ever make any, just let me know about the sound in comparison, since my shunt subjective experience is limited. They are posted in my RIAA thread, and here is the
link.
