R1 is part of the CRC-filter to reduce ripple of the power supply. Do a search on CRC, a very popular method for ClassA amps.
The B1 has decent PSRR since the jfet is fed by a (jfet) current source, so using a regulator probably brings little benefit. Of course feel free to experiment
Have fun, Hannes
Have fun, Hannes
AndrewT said:Is R1 the resistor from signal input to signal ground?
If so, then this sets Zin and can be any value from 10k to 100k.
The R1 is that one wich you can see on the full schematic of the B1, just between the alim (+18V) and the C1 (15000uF).
Compact enough, just warm, won't oscillate easily, readily available Mosfets, leftover unmatched SK170s. Iccs = (Vleds-3.4)/R1 (1W resistor). Start with 10R. Led string of 3 gives different Vdrop total depending on color and maker. Use green ones, more constant. I wanted it ''Kitsch LED Shunt'' so I used tricolore.
Neg reg
That would be nice, if you don't mind Salas.
Instead of the B1, I use a "JC" buffer (k170, j74) like NP's, in the Lightspeed Vol Control for my F3 and headamp (DOA-T) - both have low input Z.
It's nearly totally transparent but is very dependent on the supply - using a "rough" Toole shunt reg at present, and curious to hear the sound of yours, and also in comparison to the "Teddy-reg".
I've got a couple of quick questions. I'm got a few more parts to order, but I've got some 'spare' parts I could try.
I've got 100k Stereo pot, and a 100k stepped attenuator from a previous project. I guess I could substitute them in for a while.
What's the best way to scope and test this buffer?
I've got an oscilloscope I haven't used in years, hopefully it still works.
I found this on ebay.
It measures 200mm x 145mm x 70mm (8" x 5.7" x 2.8")
I was hoping I could fit the B1 (sideways) in a case like that and mount the jacks and controls on the front/back.
Aluminum Case
Aluminum Case
merlin2069er said:Great. So substituting pots won't make much difference then?
No, they won't.
Re: Neg reg
OK, I posted negatives. If you ever make any, just let me know about the sound in comparison, since my shunt subjective experience is limited. They are posted in my RIAA thread, and here is the
link.
jameshillj said:That would be nice, if you don't mind Salas.
link.
- B1 Buffer Preamp
