F5 power amplifier
what is the current rating of your potentiometer?
Current rating = sqrt (power rating / pot resistance)
eg.
10k 400mW vol pot has a current rating of:
Imax = sqrt(0.4 / 10000) = 6.3mA
We all know that to get long life from a resistor, that we never run it at average power that approachs the maximum rating.
Half power may give good life
Some would go to quarter power ( = 50% of max current rating) for guaranteed long life.
eg.
1/2 watt
2M pot and 1/2W using the formula gives current rating = sqrt(0.5 / 20000000 = 0.50mA
The current rating at maximum power of the 1M pot is 0.5mA !!!!!!!
As suggested earlier you can adopt either 0.35mA (half power), or 0.25mA (quarter power), as your long life current limits.
The whole track and the wiper are rated for 0.7mA.
just using a tiny part of the track does not change the current rating.
Can you actually adjust a 2M pot to 13r?
What resolution is the next step? 1r or 175r?
I have a problem, I have damaged a channel. I tried the fault. I checked the resistors, the thermistors, P1 and P2, I replaced Q1 and Q2, Q3 and Q4. The test with the powercord with lightbulb is ok.
Idss Q1 3.02 mA and Q2 3.00 mA, Q3 VGS 4.04 V, Q4 VGS 3.77 V.
When I move P2, DC output rises quickly and P1 has no effect.
The other channel is ok.
You have any suggestions?
