| Thread Tools | Search this Thread |
#161 | |
Formerly "jh6you". R.I.P.
It seems "open" in the mid centre between the upper and lower half. ... |
#162 |
Tim,
I have to correct myself, your idea is working fine (I overlooked the 1k drain R's). Also with source degen. X'ing R3 and R4 (exchange end points on one side) does even seem to give better results, after rescaling for the same bias current (but not changing R5 etc). EDIT: no it doesn't, simming error ;-) - Klaus |
#163 | |
The one and only
Pinched the front end bias is Output Source matters not
#164 |
Sounds nice... guess I'm a caveman.
Yowza, watch them pots to adjust bias - definitely start with them at zero as midway juicing 1.8 volt on 0.47 (3+ amps) bringin smoke, ehhe - gotta love how tough these mosfets are. DC offset adjustment seemed painless. Better get back and check bias... left out the thermasistor since didn't have on hand. Can I insert a R0 between 100k ground/signal ground and the 2 - 10 ohm resitors to ground? Connecting the the ground point for those 2 -10ohm to power supply ground. I'm getting faint ground loop noise and using traditional technique for creating pure ground at center of power cap bank... |
#165 |
diyAudio Editor
Can you make a power supply with just chokes and resistors and no caps? That would be thematically correct!
#166 | |
wakoo Mod ! ya have Niagara in backyard ?
my Papa is smarter than your Nelson ! tnx to thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; BAF Forum & Gallery;I'm dumb
#167 | |
#168 | |
I had a couple of prototype boards burned (don't have the time right now to make my own.) If I were to do it again I would put the output MOSFETs further apart since this thing really cooks. A 0.6 C/W heat sink is recommended. |
#169 |
Notice article suggest fairly good size of heatsinking to satisfy the c/w details. I used borderline as myself running without the therm comp thus probably not good idea, for my situation, to run it like an aleph (sizzlin).
Only listened to for about an hour late last night. Ran warm-hot but not too bad. Will check steady state over weekend. Nice immediate and natural sound. Can tell it's as stated in article, lowest distortion one yet. Gain feels higher than 15db, or seems good bit louder than my F3 (13.5db). |
#170 |
Usually I use 270 degree trimpots -- in this case multiple turn pots are probably to be recommended --
| Currently Active Users Viewing This Thread: 3 (2 members and 1 guests) | |
| Dennis Hui, Bksabath |
| Rockford Fosgate Power 20001 bd amplifier power rating?? | pachoorion | Car Audio | 8 | 8th May 2011 10:49 PM |
| Power transformers versus amplifier output power..what is your option? | destroyer X | Solid State | 38 | 9th May 2009 05:23 PM |
| McIntosh Power Amplifier Power Guard | johnnyrt | Solid State | 2 | 23rd August 2007 10:22 PM |
| Output power for a power amplifier | Progg70 | Solid State | 33 | 10th September 2006 08:44 AM |
| Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality | MARAVILLASAUDIO | Class D | 1 | 5th November 2004 04:06 PM |
| Page generated in 0.21602 seconds (65.00% PHP - 35.00% MySQL) with 11 queries |
