Old 16th April 2008, 04:19 PM   #131
zinsula is offline zinsula  Switzerland
zinsula's Avatar
Default Think current!
Originally posted by Babowana
The cross line does not exchange any signal voltage between the
left and the right. The reason is that the cross line is an potetial
zero point which is always the centre of vertically symmery in any
case with respect to the electrical potential. Just a thinking . . .
Not exactly.... voltage will sit at zero if the Idss of all JFETs is equal, otherwise it will be anywhere close zero. So far, you are right.
But this isn't important to the function.
Important is the current which flows from one half to the other wîth the signal. This current will change the voltage over R7/8/13/14.
In the F5, this current flows to ground, and here it flows to the other half of the circuit.
It is a diff pair....you have to connect the sources/emitters
Tino
Old 16th April 2008, 06:00 PM   #132
The one and only
Nelson Pass's Avatar
Default Re: Balaced alternative
Originally posted by zinsula
Conceptually, this should work, even if there is no balanced source (pre) available.
"Current Feedback" to the sources of J-Fets, as the F5. Don't know if it would count as X-ed in this case.
Anyone to comment?
Deriving the "voltage feedback" solution (as per susy patent, to the gates) will be trivial for you a-Pass-ionados.
Ciao, Tino
With some value adjustments, this will presumably work, but it is
not an X topology.
Old 16th April 2008, 09:21 PM   #133
Default F5 & PCB group buy
Mr Pass. Sorry to read you hurt yourself in weightlifting x serie. Hope you're recovering well. Thanks for the new F amp, neat design in it simplicity. Single question will FirstWatt build it or will there the opportunity for a PCB group buy ? Regards
Old 16th April 2008, 10:10 PM   #134
TimS is offline TimS  New Zealand
Default Balanced Amp
Here is a design that I have worked over a year ago, the main difference between this and a balanced F5 is the input mosfets and the biasing circuitry.
I have tried JFETs in the simulation but i can not seem to get the same gain as a mosfet (so higher distortion) and the source impedance is not as low (so lower bandwidth). But then I didn't try the 2SK370 and 2SJ108.
Cheers
Tim
Old 16th April 2008, 10:14 PM   #135
chrismercurio's Avatar
Default As I haven't made it to the bookstore....
what is the supply voltage? Is it similar to the F4 or wildly diferent?
Thanks,
C
Old 16th April 2008, 10:19 PM   #136
SCD is offline SCD  Canada
Default Voltage
The schematic that Nelson posted lists the voltage as +, - 24Vdc
SCD
Old 16th April 2008, 10:38 PM   #137
Variac is offline Variac  United States
diyAudio Editor
Variac's Avatar
Don't all First Watt Amps have variations on the same power supply?
Old 16th April 2008, 10:44 PM   #138
tms0425 is offline tms0425  United States
Lots of 18vac transformers
Old 16th April 2008, 10:57 PM   #139
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
yup;
seems that greedy boyz at BAF didn't take them all .....
my Papa is smarter than your Nelson !
tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; BAF Forum & Gallery
Old 16th April 2008, 11:00 PM   #140
I was thinking it might be economical to build the PS into a seperate enclosure and tap off of it Naim Style for the various Fx amplifiers.
What do you guys think? Is a possible, relevant, and viable option? More interested in the last 2 options as most things are possible.
C
p.s. I didn't take any traffos. Old Threshold knobs though, and awesome heatsinks!
Currently Active Users Viewing This Thread: 3 (2 members and 1 guests)
Oreda, ce
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 11:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 06:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 11:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 09:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 05:06 PM
Page generated in 0.17321 seconds (61.65% PHP - 38.35% MySQL) with 11 queries
