Closed Thread
Old 16th January 2008, 09:55 PM   #201
Variac is online now Variac  United States
diyAudio Editor
Variac's Avatar
I just thought it amusing that inductive might be more desireable because they might in fact reduce ripple a little. and more expensive non- inductive would be worse..I know the amount is teeeeny though
Old 17th January 2008, 02:21 AM   #202
Magura is offline Magura  Denmark
Magura's Avatar
Originally posted by Zen Mod
why you didn't asked ?
either increase current through input LTP , or increase values of theirs drain resistors ........... or slightly decrease source resistors of outputs .....that last is maybe best solution
It's in the tube for future playing around. As for now I'm waiting for the boards.
I though did some playing around with my previous prototype, and 200mA seems to be the point of diminishing returns.
I can't be bothered to make a birds nest, when I know that boards are coming soon.....and besides that I have other things to play with ATM
Magura
Everything is possible....to do the impossible just takes a little while longer.
www.class-a-labs.com
Old 17th January 2008, 07:44 AM   #203
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
Originally posted by hershann
For the Pumpkin - assuming the max output cap of 10uF - I guess it will still not be adequate for a headphone with input impedance of 300ohm as the LP filter will still be loping off a huge chunk of the bass.
Thinking of using the balanced output to do double duty to drive a balanced headphone too. I guess the only for this is to add an electrolytic
her shann
you can find decent electrolytics in range 100-220 uF, and you can bypass them with something nice , in range of 1-2u2 ;
just hang them ( electrolytics)on inner side of present output caps , solder 47K from output side of caps to gnd ( for bleeding those big caps ) , connect da cans and enjoy .
as I said - I tried my proto Pumpie with AKG K270 Studio ........
nota bene - do not forget to power off power amp, when you are in mood for headphones ........
naaaaaaaah......
I'm ill like a dog ........ flue almost gets me completely ..........
my Papa is smarter than your Nelson !
tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; BAF Forum & Gallery;I'm dumb
Old 17th January 2008, 12:00 PM   #204
Manu is offline Manu  Europe
Manu's Avatar
Maître Zen,
With AKG 270 corner freq will be about 20Hz with 100uF cap. Is it still oK,
or is it best to go 220uF in any case?
Wish you speedy gonzales recovery...
Old 17th January 2008, 04:45 PM   #205
naaaaaaaah......
Pardon my poor comprehension - so you mean -ve leg of electrolytic to output of film cap and +ve leg of electrolytic to resistor which is then connected to ground. So the electrolytic is not actually parallel to the film cap at all.
Old 17th January 2008, 04:54 PM   #206
steenoe is offline steenoe  Denmark
steenoe's Avatar
Your drawing is not excactly correct! The Electrolytic cap must be in parallel with the outputcap. Said in another way; you can replace the outputcap, with the electrolytic (and add the resistor as Mr. ZM said)
Edit: And bypass the electrolytic with your faverourite filmcap ofcourse I beleive there is provided for that on the Shunty boards...
Edit Edit: I would use at least 220uF, and even that, I feel is too small. I usally go for 1000uF for headphone applications like that.
One good combo that I can recommend is 470uF Panasonic FC bypassed with a 1uF Rifa PHE426 polyprop. At least that is the best sounding "cheapo" combo that I have ever heard Using a smallish cap on the output of a Headphone amp does cut the lower octaves somewhat
Old 17th January 2008, 05:44 PM   #207
diyAudio Editor
Variac's Avatar
Biggest Burleska
Yup I was trying to be clever. I know that inductance isn't important for DC so my point is that an inductive resistor is actually better in the power supply as it might (theoretically ) filter out a teeny bit noise and ripple. So part of point was that those who would blindly replace resistors with a "better" non-inductive one might be wrong...
I will never try to be "clever " again...promise...
Old 17th January 2008, 06:04 PM   #208
steenoe's Avatar
Naah, dont think so. First you were right, then you were right again!!!! Use the most inductive resistor that you can find for CRC arrangements"!!!"
You better play "clever" some more
Old 17th January 2008, 07:24 PM   #209
In that case - it's just replacing the output cap or paralleling the output cap with an electrolytic then. Since there is already a R27/R29 (100k) shunting to ground, why is there a mention of having a 47k ohm resistor connected to ground? Is that to replace R27/R29?
Will the electrolytic cap degrade the sound somewhat when the pumpkin is used as a preamp then?
her shann
Old 17th January 2008, 07:43 PM   #210
Zen Mod's Avatar
Closed Thread
Page generated in 0.12684 seconds (79.93% PHP - 20.07% MySQL) with 11 queries
