| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
#191 | |
#192 |
Hello,
this information is just taken from the S&B website. Cheers Christian.
Visit my DIY page at www.krishu.de |
#193 | |||
Previously: Kuei Yang Wang
Location: Somewhere nice on planet earth where censorship of Ideas is frowned upon
MSG Sayonara |
#194 | |
Konnichiwa,
Sayonara |
#195 | |
#196 | |
Konnichiwa,
Let us consider the TX-102 MKIII as having a primary inductance of 400H and a parasitic capacitance of 100pF. And let us also consider our load is a 100K//100pF Tube Amp with a 100pF shunt capacitance in the interconnecting cable. Let us now consider the effective input impedance of our TX-102 at 0db, 6db and 20db attenuation. Let us start with direct unity gain: Zl for 400H @ 20Hz is around 50KOhm and 2.5MOhm @ 1KHz Zc for 300pF (input capacitance of Amp, connecting cable and primary capacitance) @ 20KHz is around 26K and 530K @ 1KHz All of this in parallel with 100K leads to an input impedance of around 81kOhm @ 1KHz and 33KOhm @ 20Hz and 21KOhm @ 20KHz. For the 6db attenuation case: Zl for 400H @ 20Hz is around 50KOhm and 2.5MOhm @ 1KHz Zc for 150pF (input capacitance of Amp, connecting cable divided by 4 + 100pF primary capacitance) @ 20KHz is around 53KOhm and 1.06MOhm @ 1KHz All of this in parallel with 400KOhm (transformed up 100K load) leads to an input impedance of around 260kOhm @ 1KHz and 44KOhm @ 20Hz and 47KOhm @ 20KHz. For the 20db attenuation case: Zl for 400H @ 20Hz is around 50KOhm and 2.5MOhm @ 1KHz Zc for 102pF (input capacitance of Amp, connecting cable divided by 100 + 100pF primary capacitance) @ 20KHz is around 78K and 1.56MOhm @ 1KHz All of this in parallel with 10MOhm (transformed up 100K load) leads to an input impedance of around 878kOhm @ 1KHz and 50KOhm @ 20Hz and 77.5KOhm @ 20KHz. Obviously, in all cases the inductive/capacitive reactance is well above the specified 10K nominal impedance of the TX-102, but the differences at high and low frequencies are material. Just for fun the same calculation with a 10K//1nF IEC load, which was basically the "design normal" load for the TX-102.... Let us start with direct unity gain: Zl for 400H @ 20Hz is around 50KOhm and 2.5MOhm @ 1KHz Zc for 1100pF (IEC Load and primary capacitance) @ 20KHz is around 7.2K and 145K @ 1KHz All of this in parallel with 10K leads to an input impedance of around 9.3kOhm @ 1KHz and 8.3KOhm @ 20Hz and 4.2KOhm @ 20KHz. For the 6db attenuation case: Zl for 400H @ 20Hz is around 50KOhm and 2.5MOhm @ 1KHz Zc for 350pF (IEC Load capacitance / 4 and primary capacitance) @ 20KHz is around 53KOhm and 1.06MOhm @ 1KHz All of this in parallel with 40KOhm (transformed up 10K load) leads to an input impedance of around 36kOhm @ 1KHz and 22KOhm @ 20Hz and 14.5KOhm @ 20KHz. For the 20db attenuation case: Zl for 400H @ 20Hz is around 50KOhm and 2.5MOhm @ 1KHz Zc for 110pF (IEC Load capacitance / 100 and primary capacitance) @ 20KHz is around 72K and 1.45MOhm @ 1KHz All of this in parallel with 1MOhm (transformed up 10K load) leads to an input impedance of around 479kOhm @ 1KHz and 48KOhm @ 20Hz and 67KOhm @ 20KHz. Again, the parasitic elements actually belonging to the TX-102 MKIII are well out of contention compared to the nominal impedance of the TX-102. In fact, based on inductive and capacitive reactance of the TX-102 MKIII one might even be reasonable to re-classify the TX-102 MKIII as having a 50KOhm effective impedance if we want to be comparable to a resistor type atenuator. Sayonara |
#197 | |
Hello, I am a bit confused by this but won't mind as long as it does sound nice I'll write you an email in German to make things more clear as this is impossible for me to write in English - sorry. Why do Bent audio and the others not tell about the AVC option? Or did I miss it? What's the disadvantage? Regards Christian.
#198 |
Hello again,
Kuei Yang Wang found my mistake ... the source does not "see" the input impedance of the power amp because I did not take the attenuation into my considerations... Regards Christian.
#199 |
Well, last night I tried the exact diagram that has been posted recently.
I think that Kuei may have been correct. The sound has a different charactor than before - don't get me wrong, it sounds really great but... it is more smooth again but still very detailed & refined - but.... I have been doing a lot of work on my CD player aswell so it's a bit hard to know what is causing what. paralleling the coils seems to reduce the volume. My original configuration was unusual. I was injecting the i/p signal into the secondary only, but two taps down from the top. One end of half of the primary was connected to earth the other half was completely disconnected. I have no idea what kind of bizarre effect this may have been causing. Once I have listened to this for a few days I will try the primary in series with the secondary. mike |
#200 |
Kuei,
What is the difference between having a huge amount of the secondary out of cct by having the volume turned down low in a TVC configuration and having the input going straight to the secondary and the primary earthed one end and disconnected at the other end ? Is is just a bit worse or is it a Cardinal Sin ??? mike |
| Help identifying a pair of output transformers and power transformers | mjk130 | Parts | 3 | 30th January 2009 10:44 AM |
| build my first full ranger,let's build another one:a small fullrange high end pc-spea | then_dude | Full Range | 2 | 30th November 2005 07:54 AM |
| Do i need to build main supply (240v) filter?Or build power distribution? | thomgun_lc | Chip Amps | 9 | 16th September 2005 09:52 AM |
| Looking for transformers to build +5V, +12V power supply for CD-ROM drive | Saurav | Parts | 4 | 19th September 2003 02:21 PM |
