The "Elsinore Project" Thread
Old 2nd August 2011, 02:02 PM   #941
Francois G is offline Francois G  United States
Originally Posted by Joel Wesseling View Post
I'll post a picture on the jig to get the two together aligned. Its easy to make and only adds a little extra time.
Joel
Joel,
Thanks very much for the advice and jig idea!
Francois
Old 3rd August 2011, 01:59 AM   #942
Joel Wesseling is offline Joel Wesseling  Canada
Francois
No problem
Drill a center hole "straight" through a board so the pin on router circle jig fits in snuggly.
Cut the waveguide opening first and clean out then flip and cut the tweeter
opening.
I made some lines with a square to line up the mounting holes.
The tweeter holes in subfront will need to be enlarged(shallow) to accept the back of screws.
Havent done this yet but thinking I should make the tweeter recess pocket in subfront a little deeper and use a foam gasket to seal behind mounting plate
Hope this makes sense
Joel
Old 5th August 2011, 07:34 PM   #943
diabloid is offline diabloid  United Kingdom
Finally finished crossovers and inserted inside cabinets. I used 22mm MDF cut to size and carved with router to insert passives. Once inside they covered by damping material over the top.
Now it is time for waveguides/horns, I find ready made ones which should serve the purpose in here:WG-300 - Monacor special horn front attachment - wave guide - Europe Audio they are intended for monacor, but size is the same: Any suggestions?
Old 6th August 2011, 05:57 PM   #944
jdkJake is offline jdkJake  United States
Wile it looks similar, the size of the Monacor waveguide is quite a big different from the recommended waveguide for the elsinores. Based upon the diagram they provide, the Monacor is quite a bit larger. Compare against:
http://www.customanalogue.com/elsino...ide_Design.gif
-- jk --
Old 6th August 2011, 07:25 PM   #945
Regarding your coil placements, you might want to reference:
Placement of coils in crossover networks
In particular:
http://www.troelsgravesen.dk/coils_files/coils_9.gif
-- jk --
Old 8th August 2011, 04:47 AM   #946
Joe Rasmussen is offline Joe Rasmussen  Australia
Joe Rasmussen's Avatar
Originally Posted by Aural Exiter View Post
Hi Joe,
I have been following this thread for a while and am currently building a set of Elsinore Mk Vs with a work colleague (Ian) who recently passed his crossover PCB artwork to you. I also intend to build 5 of the "Hamlets" to use in conjunction with the Elsinores in a surround setup.
My question is have you worked out the port length and diameter for the Hamlets yet ? and will the hamlets use the same waveguide arrangement with the tweeter that the Elsinores use ?
Many Thanks
Sorry for the delayed reply.
You would be best just to do the Hamlets without the Waveguides.
To do a Mk5 type Hamlet speaker I would need the boxes here with drivers mounted and Waveguide too.
Then there would be several days of work... and the result cannot be guaranteed (it would probably end up OK). And I would like to think the result would be better too. But it comes down to actually doing it. But there are no short-cuts.
I don't have Hamlet port dimensions here. I think Rob323 should have it. Or does somebody else reading this have it. I never did build the Hamlets myself.
You and Ian must be getting close to getting Mk5's ready?
Cheers, Joe R.
The "Elsinore Project" DIY Speaker System " & DIY "Trans-Amp" - 40 Watt Transconductance Amp
Soon: High Frequency Bias in Tube OPT - "Don't take anything I say as an affirmation but as a question."
Old 5th September 2011, 06:38 PM   #947
Been WAY too long since I have gotten time to advance this project. Unfortunately, life has a way of creeping up on you like that.
Anyway, it was 76F and partly cloudy this morning in Florida. A nice break from the heat and a perfect time to cut and straighten lumber!
Used a circular saw jig for the rough cuts and a set of guides for the router to fashion the end product. Man, I had no idea a router was quite this versatile! In three passes per board with a flush bit, I had perfect boards and each matched the next one exactly. This is enough for the front sub-panels, internal braces and half the back panel for what will be my "internal" box.
Next up is the side panels and then time to start assembling the pieces.
-- jk --
Old 8th September 2011, 07:38 PM   #948
Nice work with your router. Please post some more pictures as you progress.
What are you doing wrt. the wave guide?
Good luck,
Francois
Old 9th September 2011, 12:49 AM   #949
Will do.
This is a nice diversion into real woodworking for me. A heck of a lot different than the home improvement variety I typically get (have?) to do.
As for waveguides. I have bought mine from Joel. The quality of the guides Joel is having made is impressive to say the least. Highly recommended.
-- jk --
Old 9th September 2011, 02:37 PM   #950
Originally Posted by jdkJake View Post
Will do.
My wave guides came from Joel too - very nice!
Too busy at work to finish it in the next 10 days, but my Elsinores need only about 10 more hours to complete. Can't wait!
The "Elsinore Project" ThreadHide this!Advertise here!
"Proac 2.5 clone" or "Elsinore project" Joel Wesseling Multi-Way 10 26th May 2011 06:51 AM
A thread to post your "project files" critofur Multi-Way 10 21st March 2008 01:50 PM
"compact loudspeaker factory visit from "magico mini" thread Nanook Multi-Way 2 4th January 2008 08:30 AM
The "Really simple and cheap speaker designs for the newbie!" thread. Spasticteapot Multi-Way 5 19th March 2006 05:16 AM
