#91 | |
#92 | |
The more you know who you are and what you want, the less things will ever be the same. |
#93 |
Heading towards something like this now:
![]() EDIT: I was playing around with idea's and that's the one I like the most so far. It shows a dome tweeter in there which can be ignored, although I have the option to play around with swapping that middle section if the Ribbon doesn't do it for me. EDIT2: The black bits around the drivers would be recessed and lined with felt for helping with diffraction ala. Wilson etc.
#94 |
Its also now transformed into a 3.5way. The dual 12's will be side firing. This gives me a good bit of breathing room and will likely mean an end to the idea of using subs.
Driver line up: RAAL 140-15d 2x 5" C-Quenze 15cm 2x 8" Flex Unit 2x 12" still not sure which yet though, smallish volume will be a big decider.
#95 |
#96 |
OK this is the absolute final design, no really! I'm now locked into nearly all the driver choices since I've made a point of ordering them to stop me from swapping
![]() ![]() I'm giving the RAAL a go first but if it turns out I'm thoroughly dome inclined then I can swap out the tweeter and XO box as shown here: ![]() And final driver choices are: Treble(1.5Khz+): RAAL 140-15d Mids(200hz-1.5Khz): 2x 5" Q-Cuenze Bass(50hz-200hz): 2x 8" Flex Units Sub(15-40hz): 2x Peerless XLS10 The bass drivers will roll off natural and the subs will be blended to pick up the slack.
#97 |
Nice .... and now your in for some serious work
![]() edit.... well, small point ..... I think your design will benefit from a slightly slanted front on mid/woofer section ... just to make it even harder
#98 | |
#99 | |
#100 |
Sure.. its not easy to move around inside a box
In my latest box with bracing/matrix I used 12mm inside .... I used a router to make 12mm tracks...and could simply slip the matrix/bracing into place with some polyurethane foamglue ... it should not be a tight fit |
