Midrange compression drivers on a budget?
Last week I got a couple of the Tymphany compression drivers that Bill Waslo is using in his latest synergy horn project.
It's an odd compression driver. Though it's not as efficient as the competition, it's bandwidth is nearly as wide as a TAD. Which is pretty awesome considering it's $30.
It look like it will legitimately cover 700Hz-16000Hz. You might even get it to go down to 500Hz.
Hard to beat at the price.
Here is one i use in a big radial horn -
http://www.diyaudio.com/forums/multi-way/287641-hlcm-horn-loaded-compact-monitor-5.html#post4780402
