.....Nowadays you can probably get some very cheap very good tweeters from other brands that can do the job but you will then need microphone support that is okay to tweak XO component values for new different tweeter type.
Have a laugh i quote myself. Add to above is if you care for good sound quality do it that way, if you don't or just in a fast way for a period like to have some tweeter response back then just buy some cheap tweeters because that would anyhow be better than that little resonance the broken ones perform. If scheme is best audio quality try first get some new or used or loose coils, if impossible get another type and tweak XO to that one.
Buzzy,
If it helps here some nice pictures for tweeters taken apart, schroll down page there's quite many there and also how they measure without XO (link Large domes ).
