Help with bass response on my first build... - Page 9 - diyAudio
Old 20th June 2013, 07:40 AM   #81
Originally Posted by Shaolin23 View Post
Thanks Steve -
Just so we are clear, my post should read -
...then best guess the angle of the SIDES and the height, and calculate the volume of a Cone.
Add the magnet cylinder area and the cone area, to get the total area of the driver.
Steve
Old 20th June 2013, 11:40 AM   #82
wintermute's Avatar
I'm using a TA2024 with a soldered on stereo input. I'm removing the input and replacing it with a chassis mount...I'm guessing the BSC goes between the input and the board then?
TA2024 MKV Bluetooth Tripath Amplifier 2X 15 Watts 12V Fully Finished | eBay
Thanks -
Yes that's right. I'm not sure what the input impedance of your amp is but it should probably be high enough that the BSC circuit will be fine. Rod says in some circumstances a buffer is necessary, but try without one and see how it goes
Tony.
Any intelligence I may appear to have is purely artificial!
Some of my photos
Old 20th June 2013, 12:00 PM   #83
wintermute's Avatar
Another quick question -
I'm sourcing from Solen here in Canada:
Solen Electronique Inc.
Looks like the inductors are available in 20 AWG and at 0.51mH. Is this okay? For the caps and resistors, what variants are the cheapest?
Thanks in advance.
That small a difference is fine. they are often +- 5% or 10% anyway
The cheapest caps are usually bipolar electrolytics, but for small value caps I prefer to use polypropylene. I'd go with the cheapest poly caps they have there. you only need 1uf, 1.5uf and 5uF (I think they have 5.1uF) The 10uF is the one on the existing crossover. The 630uH coil is also the one on the existing crossover, so the only coil is the 0.51mH one.
For the resistors just get non-inductive white coffin types They are usually about $1.50 each. If you don't want to spend so much on the caps have a look at the bi-polar electrolytics (Though defiinitely get a polypropylene one for the 1.5uF in the notch filter. I found that electrolytics in notch filters do not perform as expected). 50V ones should be more than adequate for the power you have.
Tony.
Some of my photos
Old 20th June 2013, 12:05 PM   #84
chris661's Avatar
An alternative way of cutting down crossover costs is to use a non-polarised electrolyic cap in parallel with a small poly cap.
So for the 5uF you need, get a 4.7uF electrolytic, and add a 330nF poly cap in parallel.
It means a bit more soldering, but I'd say this gets you the best price-performance ratio.
Chris
Old 20th June 2013, 12:41 PM   #85
Tony.
I didn't realize the schematic included the existing crossover, but should have
Cheers.
Old 20th June 2013, 12:43 PM   #86
Tony.
Here are the specs:
14W at 4Ω maximal power. ( >1% THD 12@ V)
- Bandwidth: 5hz ~ 24KHZ <1Db
- Single 12V 3.5A power supply needed Idle current, 85mA
- Super sized output coils rated 3A
- Rubycon buffer capacitors, 2X 16V/680uF at just 2mm from the IC
- 400V 2.2uF Audio grade film capacitor used
- 5V supply onboard
- Handy screw connectors for power/speakers/signal input, no soldering needed
- heat sink
Old 20th June 2013, 12:44 PM   #87
Chris
Thanks Chris -
How to improve bass response? NVD33 Solid State 70 7th April 2014 11:10 AM
Pencil bass response silverhairbp Full Range 2 30th April 2013 04:29 PM
Not happy with my bass response Flyin11 Car Audio 89 12th March 2008 06:09 PM
st70 bass response gongli Tubes / Valves 2 15th April 2007 09:59 PM
lost bass response Wagener Solid State 4 31st January 2007 08:06 AM
Copyright 1999-2017 diyAudio
