Need advice : Two way with RAAL 140-15D - Page 3 - diyAudio
Old 25th March 2013, 08:37 PM   #21
ScottG is offline ScottG  United States
Originally Posted by yoke View Post
Thanks, for advices...
so, SB Satori would be nice choice, and I think I will go that way...
will write email to Bendor as Scott sugested and see that option also...
Thanks once again, I will get back for some more advices once I buy drivers as am like newbie even as I have build one pair of loudspeakers (but newer fineshed them).
Because you are going active.. there is another potential solution.
I'm not sure if it will be better than the Bandor driver for your application either.. but it does sound pretty special (..having both high transparency and tone):
http://www.expolinear.de/images/stor...%20130%20g.pdf
They are only showing the "T" & "S" version here:
hifisound eShop*-*Goerlich
The "T" version is midrange-only. But the "S" version is largely comparable to the "G" (..in fact without looking real hard I'd be hard-pressed to say there is a difference):
Here you can hear one of these drivers ("G" or "S") on the Ensemble Primadonna:
Ensemble Primadonna 4 - YouTube
..not bad, eh?
Because of the smaller diameter it will be a better match for a higher crossover freq. for the RAAL. You will need to take care of that "peak" between 1-2 kHz though..
Unfortunately, not exactly in-expensive.
perspective is everything
Old 26th March 2013, 05:46 AM   #22
Face is offline Face  United States
Face's Avatar
Do you have any subs? If not, how about a three way?
"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
Old 26th March 2013, 08:43 AM   #23
yoke is offline yoke  Croatia
yoke's Avatar
Goerlich
yes those Goerlich a little expensive...and they are out of budget...plus, as I'm newbie, I think it will be a too much for me to get rid of that peak around 1-2K...
The simpier the better
I don't have plans for sub, not for music...have one, low qualiti yamaha for HT, maybe would build one more but only for HT...
dimensions of room are 3,5mx6m...listening position would be like 2.5-3m from loudspeakers
loudspeakers would be on 3.5m side...
So I think that there's no nead for sub
Old 26th March 2013, 04:39 PM   #24
@scottg
seriously? you want to recommend Driver via a bloody YouTube Video Sound sample.
hell! you are brave.
and the next Thing. a 13cm Driver for the raal 140?
Minimum would be two 13cm Driver as a d`appolito
in my expirience a big 6 1/2" Driver or a 8" Driver works super nice. the 8" Driver even a bit better Dispersion wise.
best
t
Old 26th March 2013, 04:52 PM   #25
best
t
Dynamically a larger driver would be a better match, but dispersion? MAYBE vertical, but certainly NOT horizontal. It's a trade off and I would personally go larger and more dynamic as well, but it certainly does not "match" dispersion.
Greg
Old 26th March 2013, 05:07 PM   #26
i guess 8" do fit. :-)
raal 140-15dam with w22 seas excel 0-50 horizontally.
measurement is windowed, so 500/600hz and up.
Old 26th March 2013, 05:09 PM   #27
@scottg
best
t
Yup.. Having heard earlier ensemble designs using this (or a very similar) driver. Also looking over the spec.s.
A 6.5" driver usually starts having more significant pressure loss off-axis around 1.7 kHz, an 8" is closer to 1.4".. There are however some exceptions to this (based on cone profile). A 5" driver is usually closer to 2 kHz.
In contrast the RAAL is pretty much "omni" horizontally, getting the crossover right is just easier with a smaller diameter driver.
An MTM also has some problems - midrange combing, and the RAAL's 7" or so of spacing wouldn't be doing that design any favors.
Still, a 5" driver with modest xmax isn't going to produce low bass at higher volumes. What that particular driver can do is produce reasonably low bass from a smaller enclosure, just not loudly.
If you have a larger driver and crossover combo with the RAAL that works really well - Please share! EDIT: Thanks!
Old 26th March 2013, 05:12 PM   #28
Very nicely done!
What was the crossover?
Old 26th March 2013, 05:17 PM   #29
i build some speaker with raal 140 with for example hm170MN0 (6 1/2) in a 3-way. nice, but not perfect horizontally dispersion.
with 7" focal audiom midrange,
8" peerless, accuton and paper or magnesium Excels.
chose the 8" magnesium in a 16/17 litre sealed enclosure, with a 680uF cap in front. goes down to 44/45Hz -3db
Old 26th March 2013, 05:17 PM   #30
BTW, here is an example of a 8" driver very well suited to the RAAL (at least with respect to dispersion):
http://www.zaphaudio.com/temp/PHL_25...5-30-45-60.gif
The only problems is (in this case): it's a midrange.
RAAL 140-15D w/ waveguide (Results) tf1216 Multi-Way 3 16th January 2013 06:20 PM
WTB Raal 140-15D Ddd_rus Swap Meet 0 10th January 2008 05:58 AM
Raal 140-15d chrismercurio Multi-Way 17 6th November 2007 06:42 PM
RAAL 140-15D Group Buy chrismercurio Group Buys 115 28th October 2007 08:04 PM
Copyright 1999-2017 diyAudio
