#21 | |
To put things straight: I'm not advocating to replace all Neo3s by tiny Daytons. I was only trying to find the limit, where dome tweeters can work as true dipoles.
www.dipolplus.de |
#22 |
does anyone know of a motorola piezo tweeter source in the UK?
If you remember those 2" piezo cones they did, may youd know where to source them? Im thinking i might try rudolfs dipole experiment with a pair of those piezos.....
My Avatar is my Pet, I CANT lick my eyes
#23 |
#24 |
Regarding power handling - one might try to do a dipole ring of that cheap tweeters around the middle dipole - just my 2ct Michael
Audio and Loudspeaker Design Guidelines |
#25 | |
Account Disabled
#26 | |
Dipole: front/rear drivers are operated in anti-phase Both are very interesting concepts. Implemented correctly, a dipole will provide a figure eight response at the expense of displacement. I have not seen much interest in bipoles. However, they may offer the opportunity for a minimum of diffraction. As far as I understand, diffraction is a result of pressure gradients. The sound wave diffracts around the enclosure in order to equalize the pressure gradient. If both drivers are operated in phase, a pressure gradient may not be present. Assuming optimal conditions, the sound waves will support each other and a virtual "infinite baffle" may be created. Just some thoughts. Best Regards, Thadman
"It is a profound and necessary truth that the deep things in science are not found because they are useful; they are found because it was possible to find them." |
#27 | |
Account Disabled
#28 | |
all my configurations are "figure 8" dipoles. But can you imagine a "slim" 8 and a "fat" eight? Many dipoles change their 8 between slim and fat (and vice versa) along their frequency range. Only dipoles, which don't change the proportion of their 8 with frequency, are called "constant directivity" (CD) dipoles. The purpose of this thread is to discuss the conditions for a true CD dipole tweeter. You could call that an "OB purist thing", yes. Rudolf
www.dipolplus.de |
#29 |
Rudolf, any development here?
"Convictions are more dangerous enemies of truth than lies" - Friedrich Nietzsche Cardioid-like + Waveguide 2-way |
#30 |
| Dipole tweeters | firestorm | Multi-Way | 19 | 7th February 2010 02:18 AM |
| FS: Linaeum/Tandy Dipole Tweeters | rabidlistener | Swap Meet | 3 | 27th July 2007 11:16 AM |
| FS: 1 pair of aura / linaeum dipole ribbon tweeters | zobsky | Swap Meet | 9 | 13th September 2006 10:46 PM |
| Blending controlled directivity treble with dipole midrange? | 454Casull | Multi-Way | 21 | 17th September 2005 01:28 AM |
| Set of 4 Optimus Linaeum Dipole Tweeters on Ebay | The Paulinator | Swap Meet | 1 | 13th July 2005 07:30 AM |
| Page generated in 0.15926 seconds (76.51% PHP - 23.49% MySQL) with 11 queries |
