#11 | |
![]() The text in Boxsim would be foreign language for most Germans too. ![]() There has been some initiative to get an english version of Boxsim. Trouble is that the complete text is imbedded in the code - no separate language database. So UweG - the coder - shies away from excising all those textstrings.
www.dipolplus.de |
#12 |
With distributed mode transducers one can get larger than wavelength
without beaming. Dipole radiation is a natural way to use a DML. Kind regards |
#13 |
Am I completely nuts?
![]() I cut the front plates of two Dayton ND20FA to the minimum and glued them roughly together without any baffle. You can compare the size to the previous baffle above. Dipole length now is 3.1 cm. Then the same horizontal measurement procedure as before: ![]() Since I could not believe what I saw, I did the same for the backside of the dipole tweeter and moved to the other 90deg side: ![]() Green lines are for power response. Don't know why the 75deg response for the first diagram did not come up like that for the second series. Tell me that this can't be true. Both drivers together are under 19 Euro. One BG Neo3 is 79 Euro in Germany.
www.dipolplus.de |
#14 |
Hello Rudolf,
this is a really impressing - and cost efficient - result ! For vertical angles i would expect some more disturbances, but when that configuration is mounted at the right height that should be neglegible in practice. Kind regards |
#15 |
Wow, that's really impressive. And just when we'd all agreed that dipole up to 20kHz was impossible
#16 |
Nice Rudolf! Can you remove the front plate from the ND20 to cut it down or do you just mask off the dome and cut it?
Dennis H |
#17 |
Will this be a little more 'convenient':
Parts-Express.com or this: Parts-Express.com |
#18 |
You can get it for 49€ in France
It is rare that things are cheaper in France. |
#19 | |||||
![]() No removable front plate. But you can easily saw or cut around the magnet housing from the backside. Quite soft plastic, no danger of anything chipping away. I did mask off the dome, yes. Instead of simply glueing the drivers together - as I did - it could be a good idea to make a pair of mounting flanges like this: ![]() Quote:
The ND20FB-4 is larger in both directions. Both tweeters have more of a waveguide in front than the ND20FA. I fear that they might develop some sort of horn directivity before the dipole directivity disappears. Quote:
Thanks to everybody for your appreciation of my work ![]() Rudolf
www.dipolplus.de |
#20 |
That is a great pattern but how much of the already minimal power handling and low frequency extension will remain after EQ to even make it to a 3k crossover?
Scott |
| Dipole tweeters | firestorm | Multi-Way | 19 | 7th February 2010 02:18 AM |
| FS: Linaeum/Tandy Dipole Tweeters | rabidlistener | Swap Meet | 3 | 27th July 2007 11:16 AM |
| FS: 1 pair of aura / linaeum dipole ribbon tweeters | zobsky | Swap Meet | 9 | 13th September 2006 10:46 PM |
| Blending controlled directivity treble with dipole midrange? | 454Casull | Multi-Way | 21 | 17th September 2005 01:28 AM |
| Set of 4 Optimus Linaeum Dipole Tweeters on Ebay | The Paulinator | Swap Meet | 1 | 13th July 2005 07:30 AM |
| Page generated in 0.13501 seconds (83.95% PHP - 16.05% MySQL) with 11 queries |
