Large 3-ways design / build - Page 12 - diyAudio
View Poll Results: Will MJL21193's crazy design work as proposed?
Yes 57 51.35%
No 7 6.31%
Maybe. 34 30.63%
I'll laugh when it doesn't. 13 11.71%
Voters: 111. You may not vote on this poll
Old 27th January 2010, 10:02 PM   #111
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
Originally Posted by mondogenerator View Post
what a drum like sound boat hulls make.
Eeh, high density polyurethane foam is used in fast aluminum boats to dampen engine and wave slamming vibrations.
(just wait till the screw propeller starts to cavitate)
It doesn't count how one deals with winning, but how to handle a loss (© DjT)
https://www.youtube.com/watch?v=FJEzEDMqXQQ
Old 27th January 2010, 10:10 PM   #112
MJL21193's Avatar
Originally Posted by infinia View Post
Now you are going the right direction. If'n it were me I'd steal some ideas from the 18Sounds kit 8" 2 way with 80x60 horn but minus the baffle step.
Looks good, thanks for the suggestion.
Baffle step can be handled actively, as these speakers will be active. Crossover points yet to be determined - measuring response and adjusting on the fly with the DCX2496.
Originally Posted by FrankWW View Post
Those panels are cute! Very sharp execution of I-beam principle. Over kill, of course
I'm all about overkill! Thanks
Originally Posted by SaSi View Post
I am wondering if you plan to employ bracing inside the enclosure. The curved panels will make cutting and fitting the braces more complex.
Another issue that I was thinking regarding panel construction is how to make them identically symmetrical.
The idea is to not use extra bracing, that these panels should be stiff enough on their own. Time will tell - I won't hesitate to use extra bracing but only if it is needed.
Fitting the panels together will be a challenge anyway. A slight difference in symmetry would make a difference if I were to miter the corners. Since I plan on coping the corners together, it shouldn't be a problem.
Old 27th January 2010, 11:20 PM   #113
MJL21193's Avatar
Originally Posted by 5th element View Post
If it works for them it should work for you John Stiff, light and strong.
Thanks 5th,
You are obviously a learned man of discriminating taste and enlightenment!
Originally Posted by Brett View Post
I think you can do much better than either of them.I have no idea on where you're thinking of xover points, or budget, so not quite sure what to suggest.
This is always true but there are limits to every project. The 6A has the efficiency I want and the FR looks reasonable. I'm not one of those people that think that if it's good, it has to be expensive. As for budget, I don't really have one, just burn up cash as I go along but try to keep it within reason.
As mentioned above, I don't know what the crossover points are yet myself. Part of the fun will be "dialing" these in actively.
You're going to have to engineer that yourself and it's going to need CNC most likely to get the shape correct. It will be interesting to see.
Where do you plan on x-ing it? Lower than 2k, depending on flare loading looks like a no-no.
Moving to a compression driver is something I've been meaning to try and this is a good opportunity.
The horn flare will not be a problem to construct - I won't need a CNC (there were and are people that can fabricate accurately without them) and I'll try to go through the process with a few pics to show what I'm doing. I'm a bit pressed for time right now with a few different things happening but I may find time on the weekend to get started on the flare..
I don't want to cross the HF driver too low - 2-2.5k is where I want to be.
Old 27th January 2010, 11:45 PM   #114
MJL21193's Avatar
I like where youre going with the panels....foam would be tempting but i have heard what a drum like sound boat hulls make, however rigid they may be.
Had you considered fiulling cavity with polyester resin mixed with the hollow glass spheres that GRP fabs use to lighten some structures? I wouldve thought that would be mega stiff and light, though not as light as foam, and may well be miles better.
just an idea, otherwise, loving the concept.
Thanks,
I think that the foam will be as good a fill material as any, for the design objective (lightweight, extra stiff). It has some "give" which is probably better than a complete solid as far as sound is concerned. Would something like sand be better? - most likely but it would be very heavy and I want to be able to move these and not have to reinforce the floor to hold them up.
Not mentioned yet is the other advantage of this panel shape: no real parallel surfaces, both inside the enclosure and inside the panels.
Originally Posted by Cal Weldon View Post
You called?
THAT'S what I was talking about!
Old 28th January 2010, 12:27 AM   #115
5th element's Avatar
THAT makes me somewhat nervous.
What the hell are you screamin' for? Every five minutes there's a bomb or somethin'! I'm leavin! bzzzz! Now with website! www.5een.co.uk under construction.
Old 29th January 2010, 03:47 AM   #116
MJL21193's Avatar
What about his neighbours?
Foam should be at my door early next week. THEN the fun begins.
I have been thinking that I will make the baffle a bit more elaborate than pictured earlier. The body of these speakers will be veneered, with the back and the baffle painted. I'm looking to do a marble / granite effect in the paint - something a bit different.
Old 29th January 2010, 09:42 PM   #117
Cal's Neighbours relocate whenever he turns the sound on. Not by choice mind you, but their houses get physically pushed away by the wall of sound.
Don't you mean then the mess begins?
I've always wondered about making loudspeakers out of polished marble, it'll be interested to see how this turns out looking. I'd be tempted to marble effect the entire cabinet.
Edit - that's if it's someone else is finishing the cabinets for me. If it's me I'll stick with MDF >.<
Old 30th January 2010, 12:40 AM   #118
MJL21193's Avatar
Making a mess is fun too.
I like to experiment with finishes. I did a big table a few (hundred) years ago that was a dead ringer for marble, at least from a distance
For this I will try to be a bit more sophisticated in my approach and do some samples before I proceed. To get a more "real" granite effect, I have mica flakes to mix in. Black base, black candy with the mica and several coats of clear to give it depth.
More fun
Old 30th January 2010, 03:45 AM   #119
PKNJ is offline PKNJ  United States
Default Impressed....
I have to say I'm impressed with the thought put into the cabinet design. And you even thought out the construction in detail as well. I convinced it will work the way you think it will. Most of the naysayers seem to have fallen away. I voted "It'll Work" early.
The poll is closing soon. Remember folks, vote early, vote often!
Old 31st January 2010, 08:28 PM   #120
MJL21193's Avatar
Thanks again fellas!
It is strikingly like a basin A bit on the small side though.
Just about the right size for Holy Water...Amen.
It is taking forever for that casting to dry out. I may as well put my enthusiasm on hold for at least a day or two and let it dry.
Unfortunately, work in all it's glory calls tomorrow and I won't get anything "important" done. On a bright note, my foam may arrive and I get to look at that when I get home.
I've modified the front baffle some. The concept:
Somewhat more interesting looking I think.
How to build large round front horns? Studio Au Multi-Way 77 27th August 2013 12:14 PM
I'm hooked on large coax, now to build a pair. johnsonad Multi-Way 52 13th February 2009 12:16 AM
Best choices for a 3 ways design. beppe61 Multi-Way 19 25th January 2006 12:44 PM
Thinking up different ways to cover a very large box elambert Subwoofers 15 27th August 2005 02:51 PM
Copyright ©1999-2017 diyAudio
