gedlee said:I use an HP built computer with an Athalon 64(Dual) running Win XP SP2.
I suspect that the fact that I have VB 6.0 loaded is supicious since I noticed that you use VB 3. This is an outdated and obsolete version and is highly likely to cause trouble running along side VB 6.
Hi Earl,
Just letting you know that Hornresp has been upgraded to 32-bit operation, and should now work on your AMD Athlon processor computers.
Kind regards,
David
