Nice job! Great looking case. Where did you source it and what size is it?
Mine? Thanks!
Case came from the diyA store - awesome service and awesome case. These are the specs:
Galaxy 2U w/Aluminum Covers, 230x230mm size, optional fully vented top.
It's dense inside, so it's important to carefully layout.
BK
Do you know now? You click at the EDIT SECTION icon (link in my sig below) at the table and then edit or you send an email to me and tell how many boards you want.OK, I'll go for a PCB. Not sure how I'm supposed to buy it though.
Bridged operation, differential in.
Hi!
Happily awaiting the PCBs, in the meantime, planning my build:
1.
I would like to build this PCB for bridged operation driven by one differential input. Would the attached connection be the way to go? Ground is audio ground, not pin 1 on XLR which goes to chassis ground.
2.
I have a +/- 32 V PSU box. Could I power the gainclone from this instead of buying more transformers? Would I connect it directly to the big filter capacitors?
Best regards!
Hi!
1.
2.
Best regards!
The connection according your picture is correct. You can of course connect DC. Please consult the schematics for this.
Thanks! This will be fun=)
peranders I am finally building the board (the red one)
Would you mind explain the large amount of parallel resistor installed at the output of the op amp and the ones at the bypass. Wouldn't they replace it with one high quality resistor even better (e.g caddock MP 0.1R )
Maybe here at #17?
BK
- Group Buys
- Pavel Dudek's super Gainclone group buy
