| Group Buys Members group buys |
| View Poll Results: Surface Finish for future PCB´s | |||
| ENIG - Electroless Nickle/Immersion Gold |
41 | 43.62% |
| Immersion Silver |
30 | 31.91% |
| Immersion Tin |
15 | 15.96% |
| OSP - Organic Solderability Preservatives |
8 | 8.51% |
| Voters: 94. You may not vote on this poll | |||
#921 |
The new Red Baron aka TDA1541A DAC V4.0 ![]() The evolution brings the following changes - Separate I2S-GND route to Digital-GND - Separate Analog Output GND route - Separate GND route for active divider decoupling caps to Analog-GND - Modified active divider decoupling pads for better SMD 1210 caps soldering - Onboard SOT353 footprint for fastest DEM-Synchronizer IC´s - Un-interrupted ground plane - MOSFET Source/Drain failure corrected Still on the module - Direct shunt voltage inputs with shortest onboard traces - I2S In-/Outputs with shortest onboard traces - I2S Attenuator and DEM Synchronizer (by -ecdesigns-) - Onboard Grounded-Gate MOSFET Current Buffer I/V Stage (-ecdesigns- MK7 version) - Separate GND-Trace for DEM-Synchroinizer - Master/Slave connectors for parallel DAC module usage and external I/V Buffer stages e.g. Tube-I-zator & DDNF Stage - no SMD Design[/B] ![]() The PCB has the following data: Material: FR4 - 2mm Layers: 2 Board size: 125x73 mm Surface finish: Immersion Gold Copper weight: 35µm Soldermask: Both sides - red Silkscreen: Legend on top Comming soon... ![]()
Reference TDA1541A DAC project PCB´s / Tube-I-zator PCB / SSHV-Shunt PCB
Stock status in my Blog |
#922 |
Why are the decoupling caps so far away from the TDA? They should be underneath, is the ground plan still cut in half under the TDA?
#923 | ||
Hi regal,
The the decoupling caps trace length is 6.4mm max. with a resistance of 4mOhm. However, with a pure SMD design you could save the 4mOhm, but is this still audible... ![]() With this real short trace length it sounds fantastic, especially with John´s recommended SMD caps. ![]() Quote:
#924 |
The new Red Baron aka TDA1541A DAC V4.0 ![]() The evolution brings the following changes - Separate I2S-GND route to Digital-GND - Separate Analog Output GND route - Separate GND route for active divider decoupling caps to Analog-GND - Modified active divider decoupling pads for better SMD 1210 caps soldering - Onboard SOT353 footprint for fastest DEM-Synchronizer IC´s - Un-interrupted ground plane - MOSFET Source/Drain failure corrected Still on the module - Direct shunt voltage inputs with shortest onboard traces - I2S In-/Outputs with shortest onboard traces - I2S Attenuator and DEM Synchronizer (by -ecdesigns-) - Onboard Grounded-Gate MOSFET Current Buffer I/V Stage (-ecdesigns- MK7 version) - Separate GND-Trace for DEM-Synchroinizer - Master/Slave connectors for parallel DAC module usage and external I/V Buffer stages e.g. Tube-I-zator & DDNF Stage - no SMD Design ![]() The PCB has the following data: Material: FR4 - 2mm Layers: 2 Board size: 125x73 mm Surface finish: Immersion Gold Copper weight: 35µm Soldermask: Both sides - red Silkscreen: Legend on top In Stock The price will be as followed: Professional 2-Layer PCB: $15 Worldwide shipping: $ 9 Europe shipping: $ 5 paypal fee: 3,9% A donation of $3 USD to diyAudio will be done for every pcb sold. The DAC module V2.3 will still be available for those, who want to use it without the TDA1541A Shunt module! If you want to use the onboard Grounded-Gate MOSFET Current Buffer I/V Stage, you need additionally the DC-Reference Module Description Because the Grounded-Gate Buffer is connected between the DAC output and the passive I/V resistor, normally the I/V resistor is connected between the DAC output and GND, you must get rid off the approx. 4V DC on each I/V resistor. Therefore we must get a new reference GND for each channel. The circuit is connected to the ref.+5V at the output of the buffer and GND, with a decoupling cap for each channel. By trimming each voltage so it exactly matches DC voltage on the I/V resistor, the DC voltage between I/V resistor and reference becomes zero. In other words, the DC component is removed without using a coupling cap. ![]() ![]() Material: FR4 - 2mm Layers: 2 Board size: 54x34 mm Surface finish: Immersion Gold Copper weight: 35µm Soldermask: Both sides - red Silkscreen: Legend on top Following parts are needed: 2* 2-Way vertical header; 5mm pitch - Mouser Part No.: 571-2828362 2* 470µF/min. 10V decoupling cap - Mouser Part No.: 647-RR71A471MDN1 2* 1K0 multiturn trimmer - Mouser Part No.: 652-3006P-1-102-LF In Stock The price for it is $9 Worldwide shipping: $ 4 paypal fee: 3,9% You could see the setting points for the onboard I/V stage HERE. ![]()
#925 | |
nice upgrades, indeed ![]() Solid ground plane especially, better soldering pads for 1210 too. As you already have those PCBs in stock , so I will send you PM soon for order.It would be fine if you show us layout of downside of your Red Baron. |
#926 | |
#927 |
Thank you very much for the modules! Quality, service and price = top class!
I will post the result here. For the moment I am in the process of purchasing the parts. I am gonna try some Philips blue MKT caps instead of "classic" Wima for decoupling caps. Best wishes to all! |
#928 |
got mine pack as well (V4, PS, DDNF)!
hell yeeeeee, these are just splendid, real hi-end product! and yes, it does worth every cent! I'll keep it on my table for few week to enjoy thank you, Oliver! Especially the red dac board is very sexy!Has anybody gone for a different 10uf cap on DDNF board than Supreme? I was advice by Oliver to use EVO, but found that old Russian teflon caps are highly regarded and advised for DBC1 (output) and My Rev FE (input) and even superior or at least same quality as Supremes. The combination is FT3 + K75. So I wonder if anybody could provide any input on these. EVOs are fine with me, just like the look and dimensions (110x55) of K75
#929 | |
I am using FT-3 .22 uF as a coupling cap in my tube amp. I feel that it is a good cap in this position, but please keep in mind that they are very large. |
#930 | |
Bypassed with a FT3 teflon is a good idea. Go ahead!
| i2s bus vs. i2c bus | Doovieman | Digital Source | 9 | 5th February 2013 02:08 PM |
| My take to the "Reference" TDA1541A DAC with I2S-BUS architecture | dvb-projekt | Digital Line Level | 130 | 30th January 2011 01:54 PM |
| what is "ground bus"? | gychang | Parts | 4 | 12th November 2007 09:21 PM |
| PCM2707 I2S out to TDA1541A DAC | TV Man | Digital Source | 3 | 4th December 2004 05:53 PM |
| A real DAC Philips TDA1541A "Double Crown"? | dbhh | Digital Source | 17 | 7th May 2004 05:15 AM |
