Group Buys Members group buys
"Reference" TDA1541A DAC with I2S-BUS architecture
View Poll Results: Surface Finish for future PCBs
ENIG - Electroless Nickle/Immersion Gold 85 48.57%
Immersion Silver 49 28.00%
Immersion Tin 23 13.14%
OSP - Organic Solderability Preservatives 18 10.29%
Voters: 175. You may not vote on this poll
Old 25th October 2012, 08:30 AM   #851
Pocoyo is offline Pocoyo  Indonesia
Pocoyo's Avatar
Originally Posted by dvb-projekt View Post
Hi Pocoyo,
the small pcb above the DAC V2.3 is the I2S switch (USB/SPDIF).
All BOMs you will find in my blog HERE.
Hi Oliver
I think i will build your dac with simple structure (No Need USB)
can i connect the digital input / RCA to TDA 1541 PCB ?
so the pcb we need (pls corect me if something missing)
1. PSU Pcb
2. Shunt Reg PCB
3. Shunt Reg +5v PCB (optional)
4. TDA 1541 PCB
5. HV Shunt Reg PCB
6. Tube i zator PCB
7. ??? (what for)
Thank you Oliver, best regards
Old 25th October 2012, 05:15 PM   #852
dvb projekt is offline dvb projekt  Germany
dvb projekt's Avatar
Originally Posted by Pocoyo View Post
Hi Oliver
1. PSU Pcb
2. Shunt Reg PCB
4. TDA 1541 PCB
5. HV Shunt Reg PCB
6. Tube i zator PCB
7. ??? (what for)
Hi Pocoyo,
my DAC has a I2S input. If you want to use a Digital RCA (S/PDIF) input you need two additional pcbs.
1st the S/PDIF to I2S converter, e.g. the Twisted Pear S/PDIF Tranceiver Module
2nd my UHS-Buffer Module
It looks like here:
Reference TDA1541A DAC project PCBs / Tube-I-zator PCB
Stock status in my Blog
Old 26th October 2012, 07:08 PM   #853
Pocoyo's Avatar
just asking before buying
is that right tda1541 use 12pcs x 0.22uf wima ?
if i look in the other structure they used 0.022 uf
looks like i need to buy from you
- 2 pcs UHSB, still got in the stock ?
btw
- i didnt look you use I2S switch pcb what happen ?
- as u give a bigger tda1541 pcb, is that ok if i cut the
pcb below " master / slave " ? any distortion later ?
( i need a little pcb, so easier to put into 1 chassis )
- if i look in page 48 there is mods ssr from 5v to 3.3v
what for the mods ?
best regards
Old 28th October 2012, 03:46 AM   #854
Pocoyo's Avatar
btw
what for the mods ?
i got the answer on page 50
- i2s switch for other signal input maybe for i pad
- i can cut the board it will be green baron
- mods for uhsb from ecsdesign / john brown
Old 4th November 2012, 05:18 PM   #855
crobbins5421 is offline crobbins5421  United States
Default Help needed.....
Hello everyone.
I've owned this DAC for a long time and enjoy it very much...thanks Oliver! I've also recently added The Red Baron board...even better. I utilize the Teralink X2 (no clock mods - I can't microsolder, but I did do the 5V and 3.3V shunt mods)
My original build is posted #571.
The "digital landscape" is changing rapidly and I'm starting to try new/different USB to I2S converters. I recently purchased this one in I2S output:
TAS1020B-based Asynchronous USB to I2S/SPDIF converter 24bit/96kHz
My problem is that the output is faint music covered with a veil of static and hiss. The creator of the board has been extremely responsive and helpful, but he doesn't understand the dac chip like the folks here. I know there are no problems with the DAC board, as I reconnected the X2 and everything was back to normal. You can't see the I2S connections, as they're under the board, but I've rechecked multiple times and they're correct. I think I'm missing something silly here.....
Input welcome....
I'm attaching a picture of the build (and yes, that's a Barbie...long story)
Old 6th November 2012, 12:26 AM   #856
neda is offline neda  United States
neda's Avatar
Hi Crobinns5421,
How was the sound before the Red Baron? Any noise at full volume with no music playing? The reason I ask is, I too upgraded to the Red Baron, and now I
have some sort of ground loop making the unit inoperable. I'm in the process of trying to quite this thing down.
Where is your star ground point? I don't see it in the picture.
Ned
Old 6th November 2012, 01:33 AM   #857
Default I didn't use one...
I didn't use a star ground before or after The Red Baron. With the Teralink X2, there is no noise whatsoever...
Old 11th November 2012, 12:50 PM   #858
Default USB and Digital Ground Points...
Oliver (and everyone),
I looked at your system picture, but I couldn"t tell where you had the following grounded:
1. 5V High Speed Buffer
2. USB Isolator
3. Digital Power on Red Baron
4.USB to I2S Converter
Thanks!
Old 11th November 2012, 01:48 PM   #859
2. USB Isolator
Thanks!
Hi Chris,
1. High Speed Buffer GND to +5V Shunt GND
2. USB Isolator GND to +5V Shunt GND
3. You could use only one (Analog/Digital) GND of the Red Baron, because they are star grounded on the pcb. Connect the GND to the TDA1541A Shunt GND. (see attached photo)
4. USB to I2S Converter GND to +5V Shunt GND
I hope this helps! BTW, i will dispatch your two ordered add. UHS-Buffer tomorrow.
Old 11th November 2012, 02:44 PM   #860
Default Thank you!
Thanks Oliver.
Could you also send me:
(1) +/- Power Supply Board
(1) 5V Shunt Board
"Reference" TDA1541A DAC with I2S-BUS architectureHide this!Advertise here!
My take to the "Reference" TDA1541A DAC with I2S-BUS architecture dvb projekt Digital Line Level 131 4th May 2016 12:20 PM
i2s bus vs. i2c bus Doovieman Digital Source 9 5th February 2013 03:08 PM
what is "ground bus"? gychang Parts 4 12th November 2007 10:21 PM
PCM2707 I2S out to TDA1541A DAC TV Man Digital Source 3 4th December 2004 06:53 PM
A real DAC Philips TDA1541A "Double Crown"? dbhh Digital Source 17 7th May 2004 06:15 AM
