"Reference" TDA1541A DAC with I2S-BUS architecture - Page 110 - diyAudio
Go Back   Home > Forums > Commercial Sector > Group Buys
Group Buys Members group buys
View Poll Results: Surface Finish for future PCBs
ENIG - Electroless Nickle/Immersion Gold 80 47.62%
Immersion Silver 49 29.17%
Immersion Tin 22 13.10%
OSP - Organic Solderability Preservatives 17 10.12%
Voters: 168. You may not vote on this poll
Old 26th August 2013, 07:34 AM   #1091
dvb projekt's Avatar
Originally Posted by dvb projekt View Post
Bargain Sale
Here you could order two of my ready build Red Baron V4.0 DAC test modules,
witch includes the new 3.3V I2S attenuator and free running DEM oscillator modification.
Also on board is the Tube-I-zator bandwidth limiting modification.
Main Parts
- DEM decoupling with Cornell Dubilier Stacked Metallized Film Capacitors 1F/16V FCA 1210 caps
- PRP resistors
- Nichicon FPCAP R7 series capacitors
for the special price of
$55 each
including
Worldwide shipping and paypal fee
Both sold!
Reference TDA1541A DAC project PCBs / Tube-I-zator PCB
Stock status in my Blog
Old 30th August 2013, 11:22 AM   #1092
hello again,
a question most likely to Oliver or anybody who's used twistedpearaudio's spdif receiver.
I'm unable to find the tristate dip switch and according to the manual and Oliver's post here it should have AIF/MS turned on.
Frankly speaking I didn't get the idea how the damn switch works from the manual. Could anyone please assist, should it be wired as on the pic below?
Old 30th August 2013, 04:19 PM   #1093
merlin2069er's Avatar
Send a message via MSN to merlin2069er
Just got some chokes for the tube stage.
Old 30th August 2013, 04:23 PM   #1094
Default Layout
I'm thinking I'll but all the digital stuff in a box...
ie transformers, 2x psu and the regulators
Then use a military type connector to connect these voltages to another box which would house just the red baron dac itself, and the tube stage (with it's own analogue PSU).
Some how I'd have to ground both sides, and power up both sides.
Would this cause a problem?
Old 1st September 2013, 04:05 AM   #1095
wlowes is offline wlowes  Canada
wlowes's Avatar
Cool Good source for Jfet 2SK170BL
Anyone needing the 2SK170? Ebay pak arrived this week. Happy to report that assembled Salas shunts. They worked perfectly right off.
My source for the Jfets appears to be reliable.
2SK170 BL Original Toshiba FET N CH K170 2SK170BL x 8 | eBay
Now no excuses. All parts in hand. Need to build a chassis for this beast! Thanks Oliver for making this part easy.
Old 6th September 2013, 07:32 AM   #1096
Originally Posted by dtses View Post
hello again,
The DIP switch config on your photo is correct. Witch Red Baron version did you have?
Old 9th September 2013, 05:32 AM   #1097
Peterma is offline Peterma  Australia
Can anyone suggest a good power transformer for v5 red baron?
Old 10th September 2013, 11:33 AM   #1098
thanks! It's v3.0 configured to 3.3v and almost ready now, just need to solder the pins of spdif receiver and add 4 i2s lines.
Old 10th September 2013, 06:36 PM   #1099
Just curious, if I wanted to use an external usb i2s transport (and swap it out) would that be possible?
Old 10th September 2013, 11:13 PM   #1100
wlowes's Avatar
Not sure I am understanding your question, but I use a WaveIO card as the 'external' USB>I2S converter. Works very well with TDA1541A. Swapping is as easy as disconnecting the I2S cables and putting in a different source of I2S signal.
My take to the "Reference" TDA1541A DAC with I2S-BUS architecture dvb projekt Digital Line Level 131 4th May 2016 12:20 PM
i2s bus vs. i2c bus Doovieman Digital Source 9 5th February 2013 03:08 PM
what is "ground bus"? gychang Parts 4 12th November 2007 10:21 PM
PCM2707 I2S out to TDA1541A DAC TV Man Digital Source 3 4th December 2004 06:53 PM
A real DAC Philips TDA1541A "Double Crown"? dbhh Digital Source 17 7th May 2004 06:15 AM
Copyright 1999-2017 diyAudio
