Group Buys Members group buys
"Reference" TDA1541A DAC with I2S-BUS architecture
View Poll Results: Surface Finish for future PCBs
ENIG - Electroless Nickle/Immersion Gold 88 49.44%
Immersion Silver 49 27.53%
Immersion Tin 23 12.92%
OSP - Organic Solderability Preservatives 18 10.11%
Voters: 178. You may not vote on this poll
Old 17th June 2013, 03:30 PM   #1001
merlin2069er is offline merlin2069er  Canada
merlin2069er's Avatar
Send a message via MSN to merlin2069er
Default matched quads
these look ok?
Genuine Toshiba 2SK170BL 2SK170 JFET Transistor N Channel Quad Match | eBay
Old 18th June 2013, 06:05 AM   #1002
dvb projekt is offline dvb projekt  Germany
dvb projekt's Avatar
Originally Posted by merlin2069er View Post
I ordered from this source in the past. No problems!
http://www.ebay.com/itm/4x-Toshiba-O...item4d0d70e60a
Reference TDA1541A DAC project PCBs / Tube-I-zator PCB
Stock status in my Blog
Old 18th June 2013, 03:33 PM   #1003
Originally Posted by dvb projekt View Post
Did you see the offer on DuchAudioClassics.nl ?
For sale: NOS Philips TDA1541A S1 single crown
I've contacted them, no reply yet.
Old 18th June 2013, 03:36 PM   #1004
Oh, I just ordered the jfets... quads in matched pairs. That should be ok, right?
Old 19th June 2013, 10:33 AM   #1005
Matched are not necessary, but ok...
Old 19th June 2013, 10:34 AM   #1006
Exclamation The new Red Baron DAC Module V5.0
The new Red Baron
V5.0
The evolution brings the following changes
- Jumper for I2S / simultaneous mode
- latest 3.3V attenuator for I2S & simultaneous mode (by -ecdesigns-)
- free running DEM oscillator (by -ecdesigns-)
- additional U.FL pads for I2S & simultaneous mode
- Separate U.FL-GND route to Digital-GND
Still on the module
- Separate I2S-GND route to Digital-GND
- Separate Analog Output GND route
- Separate GND route for active divider decoupling caps to Analog-GND
- Modified active divider decoupling pads for better SMD 1210 caps soldering
- Un-interrupted ground plane
- Direct shunt voltage inputs with shortest onboard traces
- I2S In-/Outputs with shortest onboard traces
- Onboard Grounded-Gate MOSFET Current Buffer I/V Stage
(-ecdesigns- MK7 version)
- Separate GND-Trace for I2S / simultaneous mode attenuator
- Master/Slave connectors for parallel DAC module usage and external I/V Buffer stages e.g. Tube-I-zator & DDNF Stage
- no SMD Design
The PCB has the following data:
Material: FR4 - 2mm
Layers: 2
Board size: 125x73 mm
Surface finish: Immersion Gold
Copper weight: 35m
Soldermask: Both sides - red
Silkscreen: Legend on top
In Stock
The price will be as followed:
Professional 2-Layer PCB: $15
Worldwide shipping: $ 9
Europe shipping: $ 5
paypal fee: 3,9%
Shipping insurance on buyers request!
A donation of $3 USD to diyAudio will be done for every pcb sold.
The DAC module V2.3 will still be available for those,
who want to use it without the TDA1541A Shunt module!
If you want to use the onboard Grounded-Gate MOSFET Current Buffer I/V Stage,
you need additionally the DC-Reference Module
Description
Because the Grounded-Gate Buffer is connected between the DAC output and the passive I/V resistor,
normally the I/V resistor is connected between the DAC output and GND,
you must get rid off the approx. 4V DC on each I/V resistor.
Therefore we must get a new reference GND for each channel.
The circuit is connected to the ref.+5V at the output of the buffer and GND,
with a decoupling cap for each channel.
By trimming each voltage so it exactly matches DC voltage on the I/V resistor,
the DC voltage between I/V resistor and reference becomes zero.
In other words, the DC component is removed without using a coupling cap.
Material: FR4 - 2mm
Layers: 2
Board size: 54x34 mm
Copper weight: 35m
Following parts are needed:
2* 2-Way vertical header; 5mm pitch - Mouser Part No.: 571-2828362
2* 470F/min. 10V decoupling cap - Mouser Part No.: 647-RR71A471MDN1
2* 1K0 multiturn trimmer - Mouser Part No.: 652-3006P-1-102-LF
In Stock
The price for it is $9
Worldwide shipping: $ 4
paypal fee: 3,9%
Old 19th June 2013, 01:32 PM   #1007
Awesome.
Hmm, I'd like to know a bit more about your reference PSU for the red baron. Is there a separate thread for that?
Would you happen to have the front / top / back panels cutouts in a .dwg or pdf? I'd love to have them if you'd share them.
Thanks.
Old 19th June 2013, 01:41 PM   #1008
Awesome.
Thanks.
Its all here in this thread.
If i start the housing, i could share the cutouts, sure
Old 22nd June 2013, 01:11 PM   #1009
neda is offline neda  United States
neda's Avatar
Oliver,
How would you compare the Red Baron board's, V4.0 & V5.0 when used with the Tube-I-zator? Which do you prefer?
B-R
Ned
Old 22nd June 2013, 01:23 PM   #1010
Originally Posted by neda View Post
Oliver,
B-R
Ned
Hi Ned,
definitely the V5.0 with U.FL connection.
I dont know if its the new layout, the U.FL connectors, the new Pin 4 to AGND connection with the new jumper or all together, but the sound is much more 3 dimensional and instruments are so realistic.
and this with I2S input! What sound may we expect in simultaneous mode with Ians pcm board.
Lets see
Oliver
"Reference" TDA1541A DAC with I2S-BUS architectureHide this!Advertise here!
My take to the "Reference" TDA1541A DAC with I2S-BUS architecture dvb projekt Digital Line Level 131 4th May 2016 11:20 AM
i2s bus vs. i2c bus Doovieman Digital Source 9 5th February 2013 02:08 PM
what is "ground bus"? gychang Parts 4 12th November 2007 09:21 PM
PCM2707 I2S out to TDA1541A DAC TV Man Digital Source 3 4th December 2004 05:53 PM
A real DAC Philips TDA1541A "Double Crown"? dbhh Digital Source 17 7th May 2004 05:15 AM
