Old 15th November 2005, 06:17 PM   #1
kmj is offline kmj  Sweden
kmj's Avatar
Default Fostex 168Esigma vs. Audio Nirvana 6.5
I'm about to build the Heruka with Fostex 168Esigma drivers. I then read at a German retailer that Audio nirvanas 6.5" could be used as a substitute to the more expensive Fostexspeaker, but does anyone here know how these two brands and models compare to each other?
best regards
Ken
Old 15th November 2005, 06:23 PM   #2
Alain Dupont's Avatar
kmj,
Take a look at:
http://www.commonsenseaudio.com/comparison.html
I didn't yet have a chance to listen to them...
Alain.
Old 15th November 2005, 06:26 PM   #3
kmj's Avatar
Alain Dupont
Thanks, but specs doesn't tell my much i'm sorry to say.... So if someone has acually heard them feel free to tell me
Edit.
They didn´t compare specs for the 168EZsigma. (missed a "Z" earlier)
Old 15th November 2005, 07:09 PM   #4
zobsky is offline zobsky  India
zobsky's Avatar
Originally posted by kmj
Alain Dupont
Edit.
the AN speakers are mid-q (read as suited to bass reflex , TL etc ) speakers vs. the low q (suitable for horn loading) fostex 168EZ, 166E etc ...
from vague reading (search audioroundtable.com), they were decent sounding at best, nothing truly exceptional
YMMV
"Any fool can know. The point is to understand" - Albert Einstein
Old 15th November 2005, 07:56 PM   #5
I had read the same as Zobsky. They are decent, but don't compare to the 206E, 166E. The Sigma's are a step above those drivers, so if you have the choice, I'd go with the 168E Sigma.
Old 15th November 2005, 08:16 PM   #6
Zoran is offline Zoran  Serbia
FE168 sigma (first model without E) is an excelent driver
wery fast with god bass responce for the full range driver
not so expencive but maybe it is harder to find "old" model...
actualy the driver is cheep for the perfomance...
As I am remember I simulate the driver in a folded voigt cabinet
results was more then excelent if we can say so...
The cabinet was very elegant (not big) and bass respose was great.
In the top end You can expect not less then curves shows.
Double cone effect can be avoided by dumping around with wool or something light.
I listened to cheeper model of FE167 in the mass loaded cabinet with 5W single ended was great for the about 60 usd cost per driver,
of course FE168sigma is much better driver...
I suggest to go to FE168sigma if You can
Old 16th November 2005, 11:40 AM   #7
kmj's Avatar
Hmm, it seems like I have to make up my mind if i'm going to build a pair of budgetspeakers or spend some more cash....
The cabinet will cost about 1/3 of the pair of sigmadrivers, Audionirvana 1/2 of the sigmas. However, as long as the AN-drivers are OK they should be worth testing. I read some of the opinions but found most comments to be about their estetics or the material of the magnet and as long as the result is good I really don't care if the magnet is metallic or polymer....
One could test the AN-drivers and use untill one gets fed up with them and then invest in a new pair, that way you'll have the next project basicly for free.
Damn, all these choices
Old 16th November 2005, 02:34 PM   #8
Kmj,
I ordered 2 * Audio Nirvana 6.5" yesterday to install in a OmegaTL
following the AudioXpress article "Omega QuarterWave Reflex" from: Rick Schultz
Ill put up the calculus and drawings soon...
It's the simplest design to test them...
Followed by a design by P. Valarcher with 2 stacked enclosures with vents for 145 lit
Plus other ideas like BL-Horn and the must !! a Replikon
In the mean time I will finish my Integrated Stereo SE 6C33C-B
Good luck with your projects...
Alain.
Old 16th November 2005, 02:53 PM   #9
kmj's Avatar
Thanks! I have no idéa what i'll get out of it but it's probably a good place to start learning
But while i'm learning i'm not picky, just tell me if they sound good or not and i'll probably be satisfied (for now)
Old 16th November 2005, 06:09 PM   #10
kmj's Avatar
Btw, how about the Coral beta 6?
Is that something worth using?
Fostex FE206E or audio nirvana super 8 cast? soundbadger Full Range 137 30th June 2011 08:04 PM
Fostex or Audio Nirvana? mikje Multi-Way 17 17th July 2008 02:12 AM
female vocals - whats cool in Fostex and Nirvana lineup? freddi Full Range 2 7th November 2007 10:04 PM
Fostex and Nirvana Single Drivers for Sale EDDIEMUNSTER Swap Meet 20 28th April 2007 03:58 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
