Old 19th October 2009, 09:56 PM   #1021
chrisb is online now chrisb  Canada
Originally Posted by planet10 View Post
Don,
The "chassis" is perfect, but the 9-pin tubes are out of place.
dave
agreed, this one definitely deserves hand-blown globe envelopes
you don't really believe everything you think, do you?
community sites t-linespeakers.org, frugal-horn.com commercial site planet10-HiFi
Old 19th October 2009, 11:00 PM   #1022
doorman is offline doorman  Canada
doorman's Avatar
Old 30th October 2009, 09:51 PM   #1023
alspe is offline alspe  Finland
Originally Posted by mteinum View Post
Winter in progress, so the last finish-touch have to wait for the spring. Moved my Dallas II in today, and what a sound! Huge soundstage, wide sweetspot and they are a lot of fun! ....and heavy
More pictures here: Dallas II - a set on Flickr
Hi. How these speakers sound with thicker heavy rock? What design they are?
Looking fukin great.
Old 31st October 2009, 12:23 AM   #1024
mteinum is offline mteinum  Norway
mteinum's Avatar
Send a message via MSN to mteinum
I like them with Living Color, Aerosmith, the remaster of Megadeths Countdown to Extinction [UDCD 765] - they all sound great. Some of the Metallica work is not the best match. This could also be the amplifiers fault, its more on the light side (SET). But, they are very detailed, big wide soundstage - easy to pinpoint instruments and vocal. The plan for the winter is two subwoofers to get some serious punch in the lower department. Its not realy needed, but....
The loadspeaker is Ron Clarke Dallas II
Ron Clarke Horns
Excellent enclosure, no need for any BSC
Hai-Fai on Flickr - Photo Sharing!
Old 3rd November 2009, 01:41 PM   #1025
mark02131's Avatar
Your speakers and room are incredible. I wish my room looked like that.
If you decided to use a sub I have heard to use multiple smaller subs to get an even bass distribution.
and check out these pearl white amps this guy built, next door on the tube's thread. What a cool match they would be with your system.
Photo Gallery
Old 8th November 2009, 04:50 AM   #1026
I built these based on Zaph's B3S design to match my TA2020 build.
Instead of going with Zaph's box enclosure I used some teardrop-shaped vases of around the same volume - they're made of spun bamboo and quite rigid. I used the B3N instead of the B3S because a square frame wouldn't suit this enclosure (aesthetically speaking). Using lots of damping and a HPF at 120hz.
The sound is as expected. Outstanding mids with clear, but a little bright, highs. Excellent detail for my jazz tastes (modern piano) and responds very well to nuanced vocalists like Feist and Regina Spektor. Not so good for rock.
Next step is to add subs. I'm thinking two paralleled in separate boxes, bi-amped with the B3Ns, and through PLLXOs.
Rob
Old 8th November 2009, 03:54 PM   #1027
chuyler1's Avatar
Another set of uFonkens I just finished as a wedding gift for a friend. I used Dark Walnut Teak Oil finish followed by 5 coats of Minwax wipe-on poly. The veneer is White Birch Band-It paper-backed. My previous set I used the iron-on Red Oak from Band-It (can be found at Lowes/Home Depot) so with this set it was a learning experience on how to get the veneer to stick. There are few bubbles but they still came out great.
Click the image to open in full size. Click the image to open in full size.
Old 8th November 2009, 06:51 PM   #1028
doorman's Avatar
Nice job, Chuyler!
I'm looking to build some computer speakers. Those could be it!
Don
Old 8th November 2009, 10:59 PM   #1029
planet10's Avatar
Beauty
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 8th November 2009, 11:03 PM   #1030
planet10's Avatar
These things are quite stunning (as in, how the h can those little things be making that music!!)
http://www.diyaudio.com/forums/blogs...arrive-uk.html
(Mark Fenlon also has a pair -- i'm currently listening to a stacked pair in the big room )
If you want to borrow a pair to try i'm sure that can be arranged.
dave
Currently Active Users Viewing This Thread: 6 (5 members and 1 guests)
conway106, Idefixes, skrstic, kaktus, skeeter99
Page generated in 0.10771 seconds (69.02% PHP - 30.98% MySQL) with 11 queries
