New Jordan driver - preliminary details
Old 30th January 2013, 01:44 AM   #211
xrk971 is offline xrk971  United States
xrk971's Avatar
If you want to use the full version newer of Mathcad (not the free version that doesn't let you save) it will probably not work on a Windows emulator as it has a picky (vile) anti piracy protector program that needs root access (admin privileges) and installation on a real pc O/S.
Old 23rd May 2013, 08:04 PM   #212
Colin is offline Colin  United Kingdom
An update to this thread now that I've trundled down to darkest Wales to visit Ted Jordan.
Ted gave me a pretty thorough dem of the new Eikonas, initially running them in a pair of 6 litre enclosures, without any BSC or EQ. They were being run in place of his usual JXR6 linear arrays.
I thought the new drivers sounded very good indeed. Better balanced than the JX92, with none of the HF lift evident on my (Vifa-built) 92s. Imaging was excellent. Overall I rated the sound as good as the arrays. And they go loud.
In the 6L box they went down to the mid-70s. From there he was blending them in with a pair of powered subs. It made for a nice, wide-bandwidth system. On a lot of music, we didn't miss the subs when they were switched off.
Ted then ran an Eikona in one of his VTL enclosures (slightly modded to take the unit). Now it had serious welly, with strong output to 35Hz or so. The wider baffle also made a difference, giving it a bit of body.
Finally, Ted ran the Eikona in a two-way arrangement with the JXR6. I'm not sure of the crossover frequency but the JXR6 didn't seem to add anything. I would say the Eikona's HF is good enough without it. I rate the JXR6 very highly but won't be using one when I get my hands on the Eikona.
Hope that's of interest. I'm looking forward to what I can do with these little blighters when I get my hands on a pair.
Old 24th May 2013, 01:58 PM   #213
northernsky is offline northernsky  Italy
In view of a possible driver update I think very intersting for older VTL Jordan owners like me to see a guide on how to modify old VTL enclosures for Eikona!
northernsky
Old 24th May 2013, 03:50 PM   #214
GM is offline GM  United States
GM's Avatar
Yes, thanks! I had a hard time justifying the 92's bang/buck, but am cautiously optimistic about its replacement if production versions work well in existing [ML]TL designs without having to trade any efficiency to 'fill' them.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 25th May 2013, 07:38 AM   #215
northernsky
There's a new VTL plan on the Jordan site and here
Eikona Loudspeaker Systems
The cutout needs increasing to 122mm. If keeping the same cutout as the JX92, the new chassis stands proud by about 7mm (i.e. the chassis rim won't fit flush with the baffle because the rest of the chassis is too wide). A turned, circular sub-baffle would sort that and enable the new driver to be fitted without major surgery to the VTL cabinet.
I thought the Eikona sounded rather nice in the VTL. I wonder how it will do in Greg's MLTLs?
Old 25th May 2013, 09:30 AM   #216
Hi, thank you for the suggestions. Currently I am using the suggested BSC with the old drivers in the VTL cabinet. It is not mentioned in the new plan: not necessary anymore?
northernsky
Old 25th May 2013, 12:35 PM   #217
Scottmoose is offline Scottmoose  United Kingdom
Scottmoose's Avatar
It'll depend on your room placement and amplifier, but in many situations, based on the published data, I suspect it will not be needed.
Old 25th May 2013, 01:19 PM   #218
GM's Avatar
Well, you have couple and have the 'ear' of the designer, so was kind of hoping you'd be the alpha tester............
GM
Old 25th May 2013, 01:39 PM   #219
rdf is offline rdf  Canada
rdf's Avatar
Hi Colin, was Ted's seating arrangement on-axis instead of the JX92's recommended crossed toe-in?
Ears aren't microphones.
Old 25th May 2013, 06:48 PM   #220
Hi RDF - The Eikona's were toed-in like the JX92s but that is his preferred set up. It wasn't necessary to get the sound balance right as it is with the 92s.
GM - got me there. After I made the remark I started wondering how to do it. Getting the drivers will be the first step …
Due to the way I built my MLTLs, I can't adjust the port length (they are buried inside the cabinet) but I think a sub-baffle will be easy enough to organise.
New Jordan driver - preliminary detailsHide this!Advertise here!
I really need some details for this driver. Boscoe Subwoofers 1 18th April 2010 05:19 PM
Driver details Twisted85 Multi-Way 7 1st November 2009 06:00 PM
details for videologic digitheatre dts sub driver please m1c Subwoofers 8 5th October 2008 01:24 AM
SMPS driver transformer details needed dhanukak Power Supplies 0 25th September 2007 07:17 AM
Jordan driver sma Full Range 0 12th February 2004 12:07 PM
Copyright ©1999-2017 diyAudio
