#11 |
frugal-phile(tm)
4" drivers instead of 3"?
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#12 |
but of course as we all know, modifying the MkI design to accommodate a 4" (Fostex or otherwise) is not particularly difficult, and could perhaps even be commercially successful ![]() funny thing is that having built both MKI & II, I vastly preferred the "smaller" design
you don't really believe everything you think, do you? community sites t-linespeakers.org, frugal-horn.com commercial site planet10-HiFi Last edited by chrisb; 28th June 2010 at 03:36 AM. |
#13 | |
There's just something I like about a bunch of wood planks. Dunno what it is. Maybe it's the way the grain fits together like a puzzle. ![]() http://i69.photobucket.com/albums/i4...n/P1140017.jpg So, I made the angle jig I found in the previously referenced link. While it isn't completely foolproof, it certainly does work. You need to be scrupulous about keeping everything perfectly square. You also need to be aware of your saw's capacity. For some angles, my 10" saw couldn't cut all the way through the 110mm wide planks, which required flipping them over and finishing the cut from the other side. This is extremely awkward when you're trying to do the 10 degree mitre and you suddenly realize you need a left handed jig. ![]() http://i69.photobucket.com/albums/i4...n/P1140015.jpg http://i69.photobucket.com/albums/i4...n/P1140018.jpg But, it all seems to fit, even better than I expected. I think I can clean up any minor imperfections with the sander. Glue will fill in the rest. ![]() http://i69.photobucket.com/albums/i4...n/P1140022.jpg http://i69.photobucket.com/albums/i4...n/P1140027.jpg All the pieces are cut. Next I need to make the circle for the speaker cutout and chamfer the back side. I have no router, so I'll do this freehand with the RotoZip for the hole and the Dremel tool for the chamfer. ![]() http://i69.photobucket.com/albums/i4...n/P1140029.jpg |
#14 |
I printed a couple templates and made the cutouts for the drivers. The CAD department at work has a plotter that can do drawings up to E size, so I also printed a full size template for the whole cabinet. I wish there were some good way to transfer the template directly onto the side panel and then I'd just build it up there. I may try to assemble as many of the internal pieces as I can, before I start to glue them to the side panel.
![]() http://i69.photobucket.com/albums/i4...n/P1140030.jpg http://i69.photobucket.com/albums/i4...n/P1140032.jpg http://i69.photobucket.com/albums/i4...n/P1140038.jpg |
#15 |
don't we all - until such time it's just a matter of spacer blocks at each corner, 3M #203 masking tape (self adjusting / adhesive temporary band clamps - a Terry Cain favorite) and patience
you don't really believe everything you think, do you? community sites t-linespeakers.org, frugal-horn.com commercial site planet10-HiFi |
#16 |
Spacer blocks? I'm not sure I've seen that trick in action. Are there any photo tutorials out there?
I once cut a spacer when attaching the front of this small enclosure. Do you mean like this? ![]() http://i69.photobucket.com/albums/i4...u/P1120560.jpg Last edited by Ty_Bower; 7th July 2010 at 06:52 PM. |
#17 | |
pretty much - if ambient temperature is cool enough that you've got decent open working time on the wood glue (10-15 minutes), you can try for at least 3 or 4 panels glued up per session
#18 | |
Most of the white versus yellow glues also have a longer working time. Gorilla glue (nasty stuff I would never use again) would also work.
None of us are leaving this world alive. Enjoy it responsibly as you may. |
#19 | |
some of the newer cabinetmaker adhesives have very quick tack time at ambient temperatures above 70F ( right now it's approx 85F on the upper mezzanine of our production floor) - this can reduce the amount of time you've got to play with adjustment a lot of white glues (Weldbond, etc) don't have the ultimate strength of yellow, but do have the advantage of drying almost clear and being easier to remove squeeze-out. (actually the newest Titebond III which has great viscosity and tacking characteristics and works very well for iron-one veneering, dries a medium brown) agree with you on the Gorilla glue- I only use it when its expansion can be helpful in gap filling (just ensure workpieces are well clamped)
#20 |
There's nothing inside them yet, but I couldn't resist lightly clamping the four sides in place just to get a feel for how they look when they're standing. To be honest, I thought they were going to be taller than they are.
![]() http://i69.photobucket.com/albums/i4...0039_front.jpg http://i69.photobucket.com/albums/i4...40040_back.jpg |
| Playing around with Fostex FF85K | Leffler | Full Range | 18 | 18th January 2013 07:15 PM |
| fostex ff85k as a mid-hi in 2 way speaker | mipop35 | Multi-Way | 0 | 1st December 2008 05:13 AM |
| Fostex FF85K for sale | lcholke | Swap Meet | 3 | 14th September 2008 06:01 PM |
| amp for Fostex FF85k | tame | Multi-Way | 0 | 28th February 2005 07:21 PM |
| fostex FW208N and FF85K | navin | Full Range | 26 | 6th June 2004 06:27 PM |
