I want these 12" field coil on ebay - Page 6 - diyAudio
Old 11th June 2010, 02:29 AM   #51
shooter is online now shooter  United States
Default no pictures
Originally Posted by haralanov View Post
Would you post some pictures? What kind of power supply feeds them?
Thanks in advance.
Right now simple solid state supply with variac to find the sweet spot, will change to tube supply eventually, also front loaded horns being built for these drivers to replace the open baffle.
Old 11th June 2010, 03:11 AM   #52
Wow, I'd love to hear about the front-loaded horns.
Old 11th June 2010, 03:35 AM   #53
The front horns are Oleg Rullit's propriety design, you can see photos of the horns here.
12" field coil pictures from woodworking photos on webshots
Old 5th March 2011, 05:49 AM   #54
jlsem is offline jlsem  United States
jlsem's Avatar
Some pictures of the horns for the Rullit drivers:
In the shop before drivers were installed.
John
Old 8th March 2011, 07:46 PM   #55
Atelier Rullit's Avatar
Hello,
recently I happened to come across this thread on your forum, and I'm very happy to see that the great project of the friend of jlsem's who was lucky, then, to purchase these unique speakers for comparably little money in my eBay auction, is currently being carried on.
Having supplied the plans and instructions, and running an alike front loaded horn in my atelier, I do know what the result will be like. There's nothing comparable to these devices.
@jlsem: Do you know whether the speakers have already been monted? I sent an email to Ka some days ago, but I haven't received an answer so far. I'm keen on getting to know everything about the course of his project. What kinds of amps is he running, what's the signal source? I'm asking because this isn't just a so-called "hifi system", but, if everything has been worked out right, a real time machine that takes you on a journey to the very place and the very time the music was recorded - be it Belafonte in Carnegie Hall, Glenn Gould in Salzburg, or whoever whenever.
One of the forum's members named me a "serious maniac", also using the word "vocation" - he might be right. For quite a lot of years I have been deeply involved in this matter, mainly re-animating old German speaker-"Baukunst" - art of construction, so to speak - and doing research for my own developments.
I suppose there are more members who'd like to know more about my philosophy, my work and my creations. From now on, I will be present in diyAudio twice a week to answer your questions, to share new projects with you, etc.
Kind regards,
Oleg Rullit
Old 8th March 2011, 09:19 PM   #56
dcathro is offline dcathro  Australia
Hi Oleg,
Great to see you here!
I have to say that I have admired your work from affar. Your drivers are incredible works of art. It is wonderful to see in our modern disposable world. It will be good to understand some of your philosophy on what makes a great driver, as well as your general audio experience.
Best Regards
David
Old 8th March 2011, 09:39 PM   #57
jlsem's Avatar
Oleg,
The speakers are mounted and are in fact outstanding. The amps are Arthur Loesch designed - single-ended currently using 801A on the output but can be configured for type 50 as well as 300B. The output transformers are Tango NY-series Permalloy core.
The whole system defies every negative myth applied to the single-ended amp/single-driver method.
John
Old 9th March 2011, 09:42 AM   #58
Hello David and John,
many thanks for your quick feedback. I'm on the move today, but I will be back tomorrow for a more elaborate answer.
I'm up to be in the forum every Monday and Thursday.
Kind regards,
Oleg
Old 14th March 2011, 10:47 PM   #59
These are the most realistic speakers I have heard and owned, the massive horn allow every detail and nuance come through, the breath of the singer, the decay of the note of an instrument is uncanny, I am done with searching for speakers, the wood work by master furniture maker jlsem is exquisite.
Old 15th March 2011, 12:07 AM   #60
Hey Shooter,
They look Gorgeous!
What is the system driving them?
Cheers
David
New 15" Field Coil Speaker deadlyvj Full Range 2 6th June 2008 03:40 AM
Sensitivity of Jensen A-12 field coil speakers korneluk Full Range 1 24th March 2008 06:05 PM
fabricating a cabinet for my 12" dual voice coil sub therich Subwoofers 3 2nd December 2007 12:39 AM
High efficiency Field coil 10" midranges, Australia tech.knockout Swap Meet 3 12th April 2006 07:28 AM
Custom 15" Field Coil Woofers *Look* Magnetar Swap Meet 10 6th July 2005 07:12 PM
Copyright ©1999-2017 diyAudio
