#11 | |
Mac OS X / Linux, Isolated Hi-Speed (480Mbps) (with automatic LSB extension correction to 32bit for True BitPerfect) USB 2.0 -> I2S (352.8k/384k/32bit) / DSD, JFET powered ES9018 DAC, JFET class A / DSD poweramps, AMT fullrange speakers |
#12 | |
I will check out the patents. I really love to explore the DIY aspects of these things. I have done planars, ribbons, and esl's. Mostly just for fun and testing and I would really love to attempt something like this. Thanks for the input. |
#13 |
Banned
I'm glad I was able to help in some small way - going off grid will hopefully prove to be another significant improvement? Let us know your findings - should be interesting in such a resolving system!
#14 |
Here is a measurement i did now with XTZ room analyzer.
It is measured with one AMT in a horn cabinet designed for five AMT drivers. The measured driver have not the latest and most linear diaphragm. I will come back with better measurements when I get the proper measuring equipment running again, and I have prepared drivers with the final diaphragms..
#15 |
I have received some questions regarding the availability of the AMTs and 8" drivers.
Both the AMTs and 8" drivers was originally designed to be commercial products. I will now finish some of the drivers as demo units and investigate if there are some companies that will take over the concepts. The sound quality are remarkable and those that have heard them have never heard anything close. The "strangest" with the AMTs are how good they play bass - this was my worry, but when I solved the resonances at lower frequencies bass was suddenly the best part... Even if they drop in level above 18kHz (due to cancelations due the size) there is no distortion and they play the highs better than AMTs that goes to 35kHz. More detail, more soundstage, more dynamic etc..
#16 |
#17 |
now this is something to follow....
#18 | |
49 - for the 16th time
"Wow sounds like a lot of engineering on your part" - This much more than that However, this claim still needs independent verification and long term reliability testing in it's intended environment - and I have a great place in mind for that. ![]() ![]() ![]() ![]() ![]()
"You can't always get what you want" K. Richards/M. Jagger *** "Next time I will know some things better" Zen Mod Last edited by c2cthomas; 10th December 2009 at 12:24 PM. |
#19 | |
![]() You seem to be very experienced in the area of design though so it is most likely that I am telling you something that you already know.
"You can't always get what you want" K. Richards/M. Jagger *** "Next time I will know some things better" Zen Mod |
#20 |
There is one aspect with the AMT that might make it even more interesting..
There are four "voicecoils" - each of 8 ohm. The AMT can be configured as a 2 ohm, 8 ohm or 32 ohm device. Pure resistive in all three configurations. Four AMTs would be needed to get full level down to 20Hz. If configured for 32 ohm and four AMTs connected in series - you then have a 128 ohm pure resistive speaker, and if you use eight AMTs in a line source you have a 256 ohm pure resistive speaker. Connected to a valve / tube OTL amplifier able to deliver 100 - 200 Volt and you have something interesting...
| Frequency range of the human voice & full range center channel speakers | jwmbro | Multi-Way | 31 | 20th January 2008 03:07 PM |
| 5.25 full range | boxcustom | Full Range | 0 | 20th March 2007 09:33 PM |
| Full Range | jered22 | Full Range | 2 | 12th January 2005 11:16 PM |
| Page generated in 0.13532 seconds (81.09% PHP - 18.91% MySQL) with 11 queries |
