#381 |
since this has become a little of a graphic design thread: try photoshop little app for iphone, it will clean app the noise pics and make them look way better. add some glow and you don't even have to tell us how they sound
![]() btw. very nice, i like white with the flavour of cone, think i'll be copying |
#382 |
My first post.
I used WinISD to calculate box for CSS EL-70. Do you see there is some major problem with my design (see pic)? Volume is 17litres and tuning 46-47hz. There would also be little driver brace inside (like in pensil70). I like this shape of the box (tall and narrow) (now 1235 x 180 x 137). pic Pensilli.doc Nice forum! |
#383 |
I'll try with a T-amp and a tube amp, and report back as soon as I can.
2 pairs built, no finish on them yet.
stew ☮ -"watch out where the Huskies go and don't you eat that yellow snow"--Nanook died of starvation 8 mos after the movie was made |
#384 |
Makk, I also like that design quite a bit. Tall and narrow has quite a bit of appeal. I have not checked your specs, but I still plan on building it anyhow. If it sounds lousy I am out fourteen dollars in chip board and a small bit of time :-) If they sound good, then all the better.
#385 | |
#386 | |
The box envisioned is awefully close to the already sorted microTower (2 drivers) or halfTower (1 driver/13.5 litre tuned to 42 Hz) ML-TLs http://homepage.mac.com/tlinespeaker...aps-150909.pdf dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#387 | |
And even if made a BR, it is not all that pretty. The dip & the bump up should be avoided. dave
#388 | |
iiiiiiiiiiiiiiii|iiiiiiii | iiiiback |iiiiiiii | front iiiiiiiiiiiiiiii| ___| iiiiiiiiiiiiiiii|____ <--- square or pipe (tuned to halfTower 42hz) iiiiiiiiiiiiiiii|iiiiiiiii| iiiiiiiiiiiiiiii|iiiiiiiii| iiiiiiiiiiiiiiii|iiiiiiiii| <-- lift to 1200 (stuffed) ______|____|_______ ground Annoying picture (sorry) hope you get the meaning.. Also it is possible to make it more narrow (more deep). |
#389 |
dMar-Ken initial impressions: compared to Morduant-Short Avant 906i floorstanders, these are easily in the same class, or better. Although, perhaps not as much apparent bass, it is more controlled than the MS's, and seem to go at least as low. They punch like a champ. Are these really only 4" drivers (CHR-70eN)? The top end isn't glaring at all, actually very smooth. The soundstage is deep and wide. Based solely on my memory (which isn't as good as it should be), I'd say these better the Fonkens w/o eN (the ones I reviewed for Affordabl$$Audio, a few years ago). Not having a pair of FE127eN Fonkens to compare them to, I can't say which would be the winner. The apparent efficiency is similar to the MS speakers as well. Without any measuring devices a little hard to verify, but the impression is that the CHR-70eNs in a P10 designed Onken style box are capable of satisfying almost all listeners. My wife, the consummate "doubter" that she is stated emphatically: " I could easily live with only these loudspeakers, they sound incredible"
My wife loves music but almost always faults speakers as not being as good as our old Castle Durham 900 speakers. We both love the old Castles. Usually she complains about not enough bass, top end too bright, mid-range too chesty...the missus' final comment:"these speakers make you want to listen to music". Not sure there can be anything more to say regarding the sound. For context the amp was my old Nakamichi Stasis "SR-2" receiver. Nelson Pass (or more correctly Threshold Corp?) licensed Nakamichi the Stasis technology. All I can say is that the "little" receiver delivered the goods. I know I could easily live with the the SR-2 and these speakers, my old Pioneer Elite cdp, and my Oracle Alex/SME 309/Grado Sig 8 setup without missing the big McCormack DNA-0.5 deLuxe/McCormack Micro Linedrive/PSIII phonostage that I usually run. Obviously the McCormack setup is more versatile, and more powerful, but it is not required with these speakers. Nelson Pass had suggested to me to use a 10 watt, 1Ω resistor per channel to lower the dampening factor. My comments are based on not following this suggestion. As soon as I can scrounge up a couple, I'll definitely be trying it .Until I get the chance to seriously listen to these with a couple of different amplifiers, my comments need to be kept within the context of the SR-2. I will try a T-amp (Nuforce Icon) and a tube amp (Phillips 6BM8 based), and the big McCormack pair. Oh, how I am looking forward to the next few days....
stew ☮ -"watch out where the Huskies go and don't you eat that yellow snow"--Nanook died of starvation 8 mos after the movie was made Last edited by Nanook; 6th March 2010 at 05:17 AM. Reason: typos |
#390 | |
![]() dave
| need great smd cap for audio application | jsaggio | Parts | 1 | 11th September 2007 04:41 AM |
| CV4014 and 5650 - any audio application of these tubes? | cm | Tubes / Valves | 0 | 18th January 2007 01:03 PM |
| Additional application for audio amps... | ashok | Everything Else | 8 | 17th August 2005 09:20 AM |
| Page generated in 0.13461 seconds (84.23% PHP - 15.77% MySQL) with 11 queries |
