| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
#11 |
Dalbani.com has good prices too.
#12 | |
Thanks |
#13 |
mcminone.com is also a great supplier for Sony & many other makes parts, but is a bit higher priced. But you should be able to find the right KSM there.
#14 |
Floric, please go to http://www.repairfaq.org/sam/cdfaq.htm
This website has many cd player problems and fixes. Anybody who is interested in CD / DVD players should read this. Try to repair the old assembly before considering buying a new one since they are so hard to find. Hopefully, you will be able to get another CD player that uses the same mechanism as yours for parts. I get all my parts except motors and optical pickups (unless good) from "donated" equipment. First of all, check the motors. Inspect top bearing for wear (bottom bearings are probably not exposed). If okay, clean and lightly lubricate (only if it is needed) using lightweight oil on both sled and spindle motor. You only need to use a little! Using a toothpick with some oil on it makes it alot easier. Next, remove, inspect for wear, and clean all gears for sled mechanism. When cleaning the gears, use a old toothbrush. This helps alot especially when cleaning the teeth on the optical pickup. It will be good as new. While the gears are out, clean and lightly regrease (silicon based) chrome bar. Afterward, manually check for smooth movement of pickup. Finally, lightly regrease (silicion based) all gears and again check for smooth movement of pickup. I have also read some pickups can be cleaned internally. |
#15 |
I need to point one last thing out. After in-depth research, some older cdplayers (some new ones also) cannot properly read extended play discs. It has something to due with the gearing ratio in the sled mechanism. This explains why my newer portable Panasonic CDP and my older Aiwa 3 disc CDP have similiar problems with the same disc. My DVD player on the other hand, reads the disc perfectly.
This is because DVD players need a different gear ratio to read the tracks (DVD has a much smaller track width than a CD). Extended play discs can have a (not always) slightly smaller track width to fit all the needed info on the disc. Sled motors can only move so slow. The gear ratio can make or break how accurately the pickup reads the data. My CDPs do not mess up on the end track. It can be anywhere on this disc. I just wish it wasn't on my favorite disc: Roger Waters In the Flesh (big Pink Floyd fan). Hopefully, we will get lucky and get ours to work properly. If not, I will just use my dvd player with my changer. |
#16 |
I have checked mcminone.com for this part. It is not available on the website nor the catalog. The only thing that comes close is on Dalbani.com. Look for SONY CD MECHANISM KSM-212ABM. The only difference is a KSS-212A pickup is used. The problem is I have heard never use a A type pickup to replace a B for performance reasons.
#17 |
Thank you for your answer e_c,
I know the repair-faq you mentioned. According to that page I have dismounted and cleaned the complete mechanism (without the laser itself). For the cleaning I used a little brush and bluetac for the gears (works really good). After that I greased all the parts that were greased before. I used "vaseline" that time - this is a very good grease that tends to harden by the time but it was the only thing that I had at hand that time and I wanted to make a test. Now my cd-player plays all my cds again but in the gaps between the tracks there is sometimes (often) a short noise (from the transport and through the speakers) as if the laser would jump a little. An inspectation of the transport showed that the gears - not only one and also the teeth of the sled are worn out. I think that it would be an advantage to have a second mechanism to swap if the old one fails. There is one shop in Germany (german website) which sells the ksm2101bam for a reasonable price, the -aam is not available there, another shop sells it for four times the price (120€) but that's too much I think. I think, I will give the -bam a try and I will report my results here. Thank you very much Floric |
#18 |
Does anyone know where I can get specs on differnet optical pickups?
#19 |
I'm not shure if the specs are published anyway. I think the manufacturer has the opinion, that they are not needed. Even the Sony support does not know much about them ("If you have a XXX, replace it with XXX...").
But maybe there is anyone with more information. Have a nice Weekend |
#20 | |
You will note, that three different laser diodes there are in use: 1) SLD104U or SLD104AGL, not to find about SONY datasheet pdf catalog I have found datasheet only about the successor type: http://www.datasheetcatalog.org/data...y/a6802787.pdf 2) ROHM RLD78MA http://www.datasheetcatalog.org/data...m/rld-78ma.pdf 3) LT022MS (see attachement) If you have an exemplare with laserdiodes about No 2 and No 3, you have a long live version All laser units (so called "optical pick up") that have inside the SLD104U, are short live versions, even the complete optical pick up is an other brand than Sony. This I have find out about the SF91 (SF-91) from Sanyo. All SF91-exemplares that I had to replace (I have make the authorized service for the older Cambridge Audio models CD-4, CD-6 and CD-T/Discmagic), had inside Sony's SLD-104U, while other SF-91 exemplares, who still perfect work until today (after more than 10 years), had inside a RLD-78 laser diode version from the brand name Rohm. Similare situation is to observe by "criminally crappy CDM12" series from Philips. This optical pick up's uses a hologram laser (include integrated foto diode matrix and high frequency pre amplifier stages) instead a simply laser diode. Comes this hologram diode from Sharp, a very large reliability and lifetime are to expect. In all other cases it is not so (particularly by optical pick up as replacement for service except that one for juke boxes and other professional stuff). Interest to know is, that are the diodes itself as original Sharp part much more expensive than a complete optical pick up for CDM12.4 Read in this case the follow threads and the additional photos about the attached links there: Laser Diode Successor of SLD-104U for SONY ESPRIT KSS Series new Brand of Hologram Laser (LDGU) LT0H30PA inside by Philips CDM12 and VAM12 mech Last edited by tiefbassuebertr; 1st January 2010 at 11:56 AM. |
| Sony optical pick-up KSS 273 A | cdun | Digital Source | 10 | 24th December 2012 11:57 PM |
| Optical Pickups | travis | Instruments and Amps | 3 | 3rd September 2008 11:21 AM |
| magnet+coil pickups, piezo pickups and Roland GK-2 midi, how does the output differ? | Puggie | Instruments and Amps | 1 | 19th September 2006 07:51 PM |
| Identifying optical pickups/ laser units | kora | Digital Source | 7 | 24th June 2005 11:11 AM |
| optical pickups | hacknet | Instruments and Amps | 11 | 15th November 2004 06:22 AM |
