| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
#231 |
If there is not enough power, it maybe cheap cable - aluminum with copper coat.
#232 |
Hello all,
I'm trying to figure out what is the difference between plain 6631 and 6631A. Is there any confirmed format and performance issue between them? I can't find a 6631A board containing 12M, 45.1584M and 49.152M oscillators separately. Some plain 6631 boards have all crystals seaparately. |
#233 | |
All the boards have 3 oscillators. I wonder if you have problems reading and seeing things ?
#234 | |
For example, description of 6631A item below tells about only two dedicated oscillators. 12M usb oscillator isn't well recognizable in photo. 24bit 192kHz USB to I2S SPDIF PCB CM6631 with Ultralow Noise 6 5UV Regulator | eBay Thank you anyway, despite your naive rudeness. |
#235 |
CM6631 data sheet states that "Only single 12MHz crystal input is required (embedded PLL function) or optional oscillator inputs for 49.152MHz and 45.158MHz". Perhaps that's why it's not necessary to advertise the mandatory presence of the 12MHz oscillator.
#236 | |||||
My sincere thanks to all too ! I just need to improve the regulator and I'll be satisfied. Last edited by KlipschKid; 6th March 2013 at 03:31 AM. |
#237 | |
I thought to get I2S out of the 6631 it just needs to be flashed with the right firmware. I ordered the exact board and wondered if I did the right thing. Mine is gonna be hooked up to an AK4396 fed by A123 Batteries. Can you recommed any XOs you tried? There are so many that claim 1ppm accuracy but unless someone has tried them against alternatives it is impossible to know what to get. Have you tried running two of those boards from one XO to see if a four or six way system can be build? Routing to different sound devices after the digital crossover shouldn't be to much of a problem with todays software options. Greets, Klaus |
#238 |
I have four now - 2 cm6631 and 2 cm6631a. I have many dacs..... akm4399, es9018, dual ad1955, wm8741, cs4398... and more. I need more ears. :-) Good cheap parts are Fox Xpresso and Euroquartz xo91. PPM is not so important - this is the measure of stability. More important is phase noise, usually measured in ps, but for some very special clocks, it can be measured in fs. Crystek CCHD-957 has lowest phase noise for 45/49 clocks. Tent labs has lowest phase noise for 12mhz. Also, some NDK clocks have very low phase noise but they are special NDK and hard to find outside japan. But to get fs phase noise needs very low noise power supply, excellent pcb, design, etc. To route out lock to many devices needs a fanout buffer and a very good pcb. my hifi uses a class-a line level crossover for bi-amping, so i don't need to use multiple cards for a pc/digital crossover. I also have this as a usb/spdif to spdif/i2s : http://myl8test.wordpress.com/audio/...fi2s-and-asrc/ Last edited by KlipschKid; 6th March 2013 at 12:49 PM. |
#239 | |
Please tell me what is the value in Windows Device Manager -> USB2.0 High-Speed True HD Audio (i.e. the diyinhk device) -> Properties -> Details -> Hardware Ids Thanks a lot! |
#240 |
Can anyone read USB descriptor of converter based on CM6613/CM6631A. Here is free software-descriptor dumper to do it. http://www.thesycon.de/tdd/tdd.exe (no instalation needed) Then we can compare the versions differences. BR JarekC |
| USB Audio Interface | oodi | Digital Source | 6 | 30th December 2011 07:59 PM |
| usb audio interface | david12 | Equipment & Tools | 14 | 10th October 2010 02:58 AM |
| Recommendation on good USB-SPDIF interface? | kop89 | Digital Source | 13 | 2nd August 2008 07:51 AM |
| Cheap Audio Interface (USB?) to PC | agm2003 | Instruments and Amps | 11 | 16th September 2007 07:48 AM |
| USB Interface Perfect?- Computer Audio | fmak | Digital Source | 3 | 4th December 2004 10:24 PM |
