| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
#11 |
Are you planning to have also AES/EBU - XLR output?
Thanks Roberto |
#12 | |
JarekC can you describe the performance for this convertor starting from stage 1 version to stage 4 version ? is it better towards the best performance......??? |
#13 |
The PCB is ready for AES/EBU-XLR output. Additional parts for this option: -XLR Connector (mounted outside the PCB) -PE65612 transfrmer -DS26LV31 driver -110 Ohm 0805 resistor -100nF 0805 capacitor Best Regards JarekC |
#14 |
#15 | |
As I wrote, it is an interesting project. But why mini-USB? People might have invested on USB A-B cables...
Is it supporting USB Audio 2.0 like the XMOS Reference Design? Thanks again Roberto Quote:
#16 |
In the standard version there is USB-B socket.
On the main PCB there no place for ADUM, so I add special doughter board. After the addition this board there is no space for USB-B so I used USB-Mini socket. I'm waiting for this doughter boards (planned delivery date March 2). TAS1020B have USB Full Speed USB Interfece (12Mb/s) and supports only USB Audio Class 1.0 I plan to design new PCB with isolation and fitted in Harmond Alu case. I also plan to design version with USB Audio Class 2.0 based on TI DSP C5xxx. In XMOS I/O pins are reclocked with 400Mhz, this I do not like. Best regards JarekC |
#17 | |
Thanks for the clarification, I stay tuned for the USB 2.0 version, I would like to order one with AES/EBU.
Cheers Roberto Quote:
#18 |
USB Audio Class 2.0 besed on TI DSP, it is now only at the planning.
TI DSP C5xxx is difficult to use for DIY beacuse of uBGA case. Now I focuses on TAS1020B, its realy good chip. JarekC |
#19 | |
Perhaps you should check this document first before saying such an error:
#20 | ||
You are not right. Look at: https://www.xmos.com/download/public...8X1373A%29.pdf In a description of the clock block in section 3.4 you find: "Note that any external clock is itself clocked-in using the 400 MHz core clock." Confirmation of this can be found here (XMOS technical forum) XMOS Support Board • View topic - External clock Respond of Larry XMOS employee: Quote:
| XMOS-based Asynchronous USB to I2S interface | Lorien | Digital Source | 1724 | 22nd May 2013 06:50 PM |
| HLLY USB SPDIF/ I2S CONVERTER | kp93300 | Digital Source | 12 | 29th January 2012 02:55 PM |
| Native 24bit 96k USB to Spdif I2S Converter Module DAC | julcat | Digital Line Level | 11 | 3rd September 2010 12:59 PM |
| FS:USB-SPDIF/I2S Converter $45 | bbp | Swap Meet | 13 | 7th February 2010 12:55 AM |
| USB to 24bit/96KHz | edpgc | Digital Source | 8 | 21st November 2004 01:40 PM |
