| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
#71 |
btw the square plug that is empty is for a headphone amp out L,R G 12+
#72 |
Probably, yes. It should be the same as RCA outputs, my guess.
#73 |
hi,
This board sounds great I am working to getting a box for it to live in it's been playing for 3 days now so we will see how it sounds in a week or so , btw I did put some small mostly vertical heatsinks on the 7808's and it did cool them a bit.still listening to diff opamps..... Happy Listening!!!!!!!!! |
#74 |
here are few pics of mine
![]() finished inside but still have some work on the case. Also considering to add optical input (need it to connect LG LED). Found several options: -just add this inside the case -use separate device -or build my own and connect it to Coax input. It looks very easy
#75 |
that's a nice rig you got going tell me what is the silver wire I can tell they run ac but what kind are they!
I will make a picture of the heatsinks I put on 7808 they are not real pretty but you can hardly feel the warm on them now I actually consider cutting them in half and let then get a little warmer,lol. |
#76 |
I don't need the USB input on a DAC. Can I simply leave off all the all parts associated with PCM2706 etc? Seems pointless to populate the board with stuff I don't need.
Joe. |
#77 |
Hi jnewbold,
Yes omit those parts and it will work fine I have one running like that . Cya! |
#78 | |
#79 | |
Anyway, I think half of a meter of this silver mains doesn't influence on anything.here are few more pics |
#80 |
Anyone can advise me on transformer to be used for this dac. I have some old toroidal transformer. I presume it's about 40-50AV with secondary output voltage 2 x 15v and 2x 10v. Do you think it would be suitable? I have also chassis mounting transformer 2x9v, 12VA. I was planning to buy 30AV 2x15v for the analogue circuit. Cheers, |
| cs8414 & wm8740 dac (one dac chip) | sparkle | Digital Line Level | 28 | 28th March 2012 01:10 PM |
| New WM8740 DAC | lordearl | Digital Source | 4 | 3rd May 2010 09:51 AM |
| DIY Dac PCBS ( DIR9001,DF1706,PCM1704) | rudee | Swap Meet | 1 | 22nd April 2009 02:04 AM |
| Problem DIY DAC / WM8740 | ah79 | Digital Line Level | 7 | 14th March 2009 05:20 PM |
