| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
| View Poll Results: Do you have a SPDIF transformer in your Digital Device | |||
| Yes |
40 | 71.43% |
| No |
16 | 28.57% |
| Voters: 56. You may not vote on this poll | |||
#101 | |
Don't know if reflections like that would cause jitter or other digital errors, I would hope the receiver chips are more immune to reflections than analog video. You know - what's the threshold before there is a timing error?
Take the Speaker Voltage Test! |
#102 |
Panomaniac,
There is nothing digital in clock recovery from the SPDIF data. It's an analog process. Data extraction is digital, with high enough safety margins to achieve very low error levels even with a noisy transmission channel. There are no data errors in SPDIF, in normal circumstances. But there is ample phase noise in the recovered clock. The "classic" Crystal receivers are using an analog PLL, phase detector+VCO. They have a PLL loop filter cutoff frequency at around 20kHz. With some peaking included. Latest receivers are presumedly better, using at least some vcxo with much lower loop filter corner, though it would be nice to be able to see independent tests, like those what John W. had been doing at diyhifi.org in the past. Ciao, George |
#103 | |
For those who are still not bored.
Previously I was accused (by wakibaki) of not being able to demonstrate a possible connection between reflections and jitter in a transmission line. I would quote: Quote:
So ok, here it is a first try at this problem. I'm again using the same 'HP generator -line-BNC tee- termination' experimental setup, with the BNC tee connected to the oscilloscope 1Mohm input. The generator is set to produce a pulse, edges are ~1.2ns, variable width from 5 to 30nsec. The test cable has an electrical length of 10ns, so the reflection shows up ~20ns after the starting edge. It looks like this - very similar as in the previous attenuator tests. Because of the continuous accusations of wakibaki, I would report here again the amplitude values from the previous (attenuators) setup: It was at pulse height 680mV, reflection peak 40mV. ratio: 5,88% Now from these graphs the pulse height is: 254mV, reflection peak is 15mV. ratio: 5,88% |
#104 |
I was thinking that a possible demonstration could be the following:
The scope is always triggered on the pulse rising edge. This rising edge is exciting the reflection, which will arrive always at a fixed 20ns. Then the pulse falling edge is varied, it is "scanning" a time interval covering /including the reflection. The object under "suspicion" is this falling edge. As it is moving along, at a certain point it will be in coincidence with the reflection. If one can observe nothing, no deformations during this transition from before to after reflection, then wakibaki is right. Another important point is that this edge should be constant shape, uniform in the different other points where there is no perturbation. For control, I'm using cursors plus the built in falling edge measurement, watch for the "delta" cursor readings, and the fall time. In the pics I'm moving backwards, 30nsec, 28nsec, reflection, finally one point before the reflection, 18nsec |
#105 |
I can assure You, the effect is real, I'm able to repeat it, but also, if one observes the falling edge, it's visibly changing shape. The built in scope measurement is quite an objective observer, too.
Both the cursors and the fall time give a ~100psec difference at the coincidence point. Consider that: I'm using a very fast edge, which is kind of a "best case" to avoid this kind of influence; but also, this edge is very close in speed to the "real case" highface driver speed; the reflection is principally generated by the BNC tee, which itself is quite close to an RCA connector, (TDR response) as I had shown it in the diyhifi.org thread. So I would consider this demonstration to be a very "lifelike" simulation for SPDIF. Previously I had shown that with the real SPDIF driver, the Hiface, I had seen this coincident reflection by simply putting on one of my real, home use SPDIF cables. Ciao, George |
#106 |
respect
#108 |
Banned
An ungracious retreat, I see without even a thank you to Joseph. I, for one, would like to extend my thanks & respect to Joe for the obvious work he has put into this.
#110 |
Banned
Maybe what's needed is a third party who is experienced enough to interpret the plots as evidence of reflections on the falling edge of the signal - otherwise it just appears as diametric viewpoints that few enough of the readers are able to judge the veracity of for themselves.
What I can judge though is Joseph's trojan efforts to satisfy your increasingly demanding requirements for proof & your rejection of these at every turn, usually with a different requirement/claim being introduced. Firstly you denied the whole concept of termination problems, then you rejected the idea of reflections on SPDIF lines, then you suggested that there never were any plots or measurements taken, then you wanted to be shown the reflections causing the timing issues at the rising or falling edges & finally now you leave when all this is apparently done. You started all this by accusing me of spreading mis-information & casting a slur on design engineers which you seemed to number yourself among & were defending - you sir, are doing more damage to your profession (if you are representative of them) than ever I could (not that I ever intended any slur)! Last edited by jkeny; 26th June 2010 at 11:38 PM. |
| generate jitter test signal and measurign jitter using AP2? | BJAMR | Digital Source | 11 | 1st November 2010 02:07 PM |
| Attenuators | stven | Parts | 0 | 12th January 2009 03:05 AM |
| Attenuators ------ Please Help | soundbadger | Tubes / Valves | 5 | 13th February 2008 04:19 PM |
| Data Jitter Versus Electrical Jitter? | 300_baud | Digital Source | 8 | 16th July 2004 07:59 PM |
| About Attenuators | leiade | Solid State | 8 | 3rd November 2002 08:54 PM |
| Page generated in 0.14135 seconds (79.96% PHP - 20.04% MySQL) with 12 queries |
