| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
It's my second thread now !
I have a scarce DF1 Conrad Johnson CDplayer / Preamp from the begining of the eighties. And with this issue : - the CD turntable motor is continuously spining at high speed as soon as power is ON, - however it is still possible to read CD ( sonically very nice ) when you press "play" button : then all things are OK, - and it is possible to get next, preview & pause functions without problem, - but if you press "stop" or "eject" buttons, spining problem on CD disc motor comes back as at the begining. This DF1 Conrad Johnson is a tweaked common Philips CD350 player with a typical Conrad Johnson treatment for D/A & preamp stages. I think problem is due to the defective IC 8bits microcontroller : MAB8441P-T042 Have you ideas about that ? I need your help. To consider it as an old scrap, grieves me !! Raymond my DF1 : ![]() and this MAB8441P :
#2 |
#3 |
#4 |
Were there some problems with the servo PCB under the pickup on these... electroylitics ? and poor joints. There was more than one motor type used too I seem to remember, DC motor, hall effect DC brushless etc.
I have an old CD150 and it looks the same as your lol Edit... Agree with analog sa... it won't be the Micro, guaranteed
#5 | |
- Servo PCB under pickup ( CDM4/28 ) is OK and no bad connections exists. The only problem is ( consider that, it reads disk perfectly ) the CD turntable motor never stop and runs at high speeds when it is'nt in a reading operation. For this reason, I think there is a problem with program memory chip as this MAB chip, located just behind face-plate : after CD recognition, CD run must be stopped, till play button will press... In addition excuse my poor English ! Raymond |
#6 |
hi, spinning at high speed indicates no clock input, i think? check saa7220.. chip. either could be a bad chip or the solder joints. if you press on the chip and the player works correctly this is normaly dry joints.
jim |
#7 | |
With "saa7220.. chip", you have in mind ERCO SAA7020 ? I changed it before and spinning speed on the CD motor is still in live ! Today my problem is it's impossible to buy these MAB8441P-T042. Dönberg Electronics in Irelan have many MAB8441 but not this T042 type ( I think it's a specific program edited for this chip ). If a diyAudio Member know where it is possible to buy it without a $300 minimum order requirement, my gratitude will be acquired for a long long long time Raymond Last edited by dray177; 30th January 2010 at 02:47 PM. |
#8 |
As part carrier you need an ordinary CD player (from Philips/Marantz e. g.), that uses exact this MAB8441P-T042 as MCU
There are many lists on the web, where to find the Brand, model-No, laser pick up and DAC chip set. But we need also the MPU/MCU types and the PCM-Decoder/Servo controller/RF-amp list for cases as your's above describted. Unfortunately I cannot discover such lists. therefore I have start this thread: Starting cross reference for LSI processors and display drivers of cd player models |
#9 | |
VERY NICE your website : http://www.tiefbassuebertragung.de/49628.html Raymond |
#10 |
Have you tried to fault find by looking at "why" the motor is receiving a run command
or what is turning the motor on ?It's "never" the chip usually... Do you have a circuit ? |
| Upgrading the Conrad Johnson Premier Fourteen preamp | Tino_diy | Tubes / Valves | 10 | 12th March 2012 02:13 PM |
| Conrad Johnson ART preamp question. | robmil | Tubes / Valves | 24 | 16th February 2011 02:59 PM |
| Conrad-Johnson PV6 Preamp | paulcurrie | Tubes / Valves | 3 | 17th April 2004 07:11 PM |
| Conrad johnson topology | Stefano | Tubes / Valves | 14 | 1st August 2003 04:32 AM |
| conrad johnson help | efoda | Tubes / Valves | 3 | 24th January 2002 03:23 AM |
| Page generated in 0.10432 seconds (82.01% PHP - 17.99% MySQL) with 11 queries |
