Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 3rd December 2008, 01:56 PM   #2411
Originally posted by ccschua
I wonder what is the connection for the LCD backlight.
The connection is 4 pin with LED + and LED -
I connected positive just after diodes plus a 5.1kohm series resistor to dim the light (10k was too dim)
Old 3rd December 2008, 02:09 PM   #2412
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
I removed all the wires and mouted 10K resistor directly on display board: V+ connected to resistor, ground to hole on a left, taken directly from PS board, before the regulator.
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 3rd December 2008, 03:49 PM   #2413
You could also install a 10K pot just in place of Peters resistor shown above and be able to adjust the light level.
Does anyone know what the normal and peak current draw of the shiga is?
Fran
Old 3rd December 2008, 05:57 PM   #2414
Fran
I'd have to search for it in one of my previous posts in this thread but I believe the operating current is 210ma on Peters 8v PS circuit.
Dan
Old 3rd December 2008, 06:20 PM   #2415
Fran
Dan
Old 3rd December 2008, 07:37 PM   #2416
Badge is offline Badge  United States
looking at the picy Peter posted with the resistor on the display board, it looks like the solder bridges the two trace points to the left-upper and lower. Is this intentional?
Another question. What resistors/value has everyone settled on for the series and shunt on the digital output?
The freaks stick together, they are a tight old crew
Old 4th December 2008, 04:45 AM   #2417
ZUM911 is offline ZUM911  Australia
Peter,
I really like your latest version of the Shigy, can you say how difficult it is to machine the acrylic? Also, I'd like to keep everything in 1 case including the transfromer. Bad Idea?
Cheers
Rick
Old 4th December 2008, 04:47 AM   #2418
I did acrylic on a table saw and use router for fine finiszing, no problem here. Be careful when drilling, though; it can sometimes chips.
Transformer can be in a same box, majority of transports is done this way
www.audiosector.com
Old 4th December 2008, 04:51 AM   #2419
Great, thanks for that. Also, were can those nifty spikes be found?
Rick
Old 4th December 2008, 04:51 AM   #2420
It actually looks like there is a bridge on a LED, but it's not. The other connections can be done in any other way, as long as it works.
I use 300/100R combo on the output (Dale)
www.audiosector.com
Copyright ©1999-2013 diyAudio
