Using the AD844 as an I/V - Page 51 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Line Level
Old 22nd July 2013, 03:35 AM   #501
georgehifi's Avatar
Send a message via MSN to georgehifi
Originally Posted by jcx View Post
increase the filter order, Butterworth is much flatter in the passband
should be inaudible at a much lower fc
since you need a buffer anyway why not make it a 2nd order LPF with Q, fc coordinated with the RC for a 3rd order Butterworth @ ~ 40-50 kHz
Nice of you to chime in JCX, can you give details on how you would do this on the BUF03 buffer without changing it's nice low 2ohm output impedance (attached) I am using?
Cheers George
File Type: jpg BUF03 buffer fed from TZ (pin5) of AD844.jpg (168.1 KB, 564 views)
Avatar : Production Lightspeed Attenuator
www.lightspeedattenuator.com
Old 22nd July 2013, 04:02 AM   #502
jcx is offline jcx  United States
in the past I'd just fire up MathCad and derive the symbolic equations myself except its expired again and I'd have to call in to reactivate my version 11 - and it still needs XP
but its not that uncommon a circuit
Google
with a dedicated unity buffer chip you're stuck with the unity gain equations unless you add another op amp for the 2nd order section -which does simplify/separate the design equations
just use the same 1st real pole RC values with the R gnded, I into the 1st RC node == Norton equivalent
but with free choice of LPF I'd use the multiple feedback filter with good VFA - for lower distortion
Old 22nd July 2013, 04:22 AM   #503
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via Yahoo to abraxalito
George -- to get high enough Q to do what jcx is suggesting with only Rs and Cs you'll need to use feedback. Alternatively, embrace inductors....
The heart ... first dictates the conclusion, then commands the head to provide the reasoning that will defend it. Anthony de Mello
Old 22nd July 2013, 05:08 AM   #504
georgehifi's Avatar
To do feeback around the BUF03, I'd need another opamp not for me, I have at the moment no global feeback from the output of the PCM1704's all the way to the speakers I think I'll keep it that way, I'll just settle for the 1st order filter at TZ of -3db @125khz
Cheers George
Old 22nd July 2013, 05:13 AM   #505
abraxalito's Avatar
The standard Sallen-Key style 3rd order filter uses a unity gain buffer so you could do it with the BUF03 you already have. But if you prefer to keep things feedback free, then inductors are the only solution I'm aware of.
Old 22nd July 2013, 05:17 AM   #506
if you use bigger than 4:1 unequal C in the unity gain buffer Sallen Key then Q>1 is possible with equal R in the 2nd order section considered alone
values have to be adjusted due to the interaction of the added 1st RC section for 3rd order Butterworth
less interaction can be had with further large impedance ratio between 1st section and the 2nd order part
as far as "avoiding feedback" is concerned - why do you think the BUF03 has unity gain in the 1st place? (hint: because it uses 100% voltage feedback internally)
and if you just don't like negative feedback then you may be entertained to know the Sallen Key is actually using positive feedback to boost Q
Old 22nd July 2013, 07:13 AM   #507
georgehifi's Avatar
It sounds magnificent as it is, I think I'll just keep it at the simple 1st order at -3db @125khz on the TZ filter. With this there is just a couple of degrees of phase shift at 20khz, and the vhf noise on the output of the BUF03 is only a couple of mV at more than >100mhz, I don't think this is detectable at all. And then this way it's very simple with no global feedback anywhere in my system.
Cheers George
Old 22nd July 2013, 04:48 PM   #508
the worry about “phase shift” is also misplaced – how long do you think the digital filter is – typically low double digits of the sample rate, 100s of degrees
so “phase shift” is not so useful a quality metric, the player already has lots – if linear with frequency it is simply a pure delay
the real “time distortion” is the variation in group delay over the audio range
for a 50 kHz 3rd order Butterworth that's ~ 700 ns of delay change from 20 to 20 kHz
or about 0.2mm (0.008”) of air path difference – how's you speaker driver alignment, what's you're driver x_max?, any baffle diffraction, room reflections? what's the radius of your tweeter diaphragm?
Cary Audio uses 3rd order analog filter
Old 22nd July 2013, 08:31 PM   #509
TNT is offline TNT  Sweden
ahhh, brought back to reality.
Thanks!
Old 22nd July 2013, 09:55 PM   #510
georgehifi's Avatar
Yes they did it was based on a opa134, every time I used it between the TZ and whichever of the two madeup output buffers I was using. The sound quality suffered everytime it was inserted. Sure the output was clean down to the baseline noise of the Tek scope, but the music just wasn't there anymore.
This is why I have been so happy with the 1st order at 125khz even though there a little bit of vhf **** now seen on the Tek scope on the outputs, the music sounds real. As Zenelectro once said to me "sometimes don't let you eyes decieve you" listen to it.
Cheers George
AD844 as a common base stage in the I/V converter Pedja Digital Source 44 14th September 2015 10:10 AM
WTB AD844 Opamps apassgear Swap Meet 6 31st January 2007 02:57 PM
Copyright ©1999-2017 diyAudio
