| Digital Line Level DACs, Digital Crossovers, Equalizers, etc. |
#21 |
isolator is only required between I2C bus and dac.
not required for other I2C devices. |
#22 | |
That is exactly what i want
![]() Quote:
#23 |
I went through some ideas with you earlier. From what I understand now you will link several atmei chips together if there is need for more programming space?
Anyways, each add on board could possibly have its own Atmega328? Here are some of the things I am thinking of: 1. Networking in order to control the dac from a iphone / android possibly with the same gui as on the 20x4 display but with buttons along the edges to select inputs and the side-buttons on the android/iphone controls volume. 2. IR-learn and blast ability. In order to just use the apple remote for every component on a secondary function on the remote (f. ins pressing center + menu to control the source for the selected input). 3. I2c extender in order to link with other components? (i2c to cat5). 4. 20x4 LCD size PCB with screw holes so that it can be mounted to the rear of the LCD. 5. 12V trigger functionality. I am running the surround reciever through the dac and switch with relays. If the dac had a 12V trigger functionality this could be automated so that when the surround reciever is turned on the relays switch to the reciever. The functionality you have listed is very good, I can see this being the controller in all my Buffalo/Opus builds. Edit: more ideas Last edited by gwikse; 16th October 2012 at 03:03 PM. Reason: more ideas |
#24 | |
CE-Designs.net |
#25 | |
2. In my opinion way to complicated to control all sources. I`d rather use a logitech harmony or similar. I have thought of using such a remote for easy access to all functions I`m planning to add, but now I`m using the apple remote and still manage to access all functions. A IR learn function to teach the control how to use any remote would be nice. No idea how difficult this is. When in teaching mode the IR codes could be written to the EEPROM so the controller would reconise them again. I`ll try to find some info on this. ![]() 3. Would you like to control anything outside the chassis with it? There is no real need for an extender as long as all slaves are inside the chassis. 4. The holes already correspond with the ones of the 20x4 LCD ![]() 5. Isn`t this normally used to switch on a power amp?
CE-Designs.net |
#26 | |
www.hifiduino.wordpress.com |
#27 | |
2. AMB audio`s lcduino system has this function so perhaps we could use that code as a start point for the ir learn function. Then it would be a matter of adding the ir blast code to each input. But I also use a universal remote atm and it works flawlessly. The only thing is that it is a little complicated for some users. A simpler remote is requested from others here in the household ![]() 3. It would be nice to be able to only use one display in the dac chassis and still have a Beta22headphone amp + Alpha20 linestage with delta1+2 input/volume system in a second chassis. It would proborably be easier to have a second controller (LCDuino) to control this, but it would be cool to control both from the same controller. Other uses might be f.ins. light control, doorbell control (when the doorbell rings the dac is muted) etc. Many things you can do with an arduino. 4. Great ![]() 5. Yes, power amps can be switched on/off by that sort of system. But also other uses like turning on a projector and lowering a motorized projection screen. |
#28 | |
I
EDIT: @ gwikse: Thanks for pointing me to the lcduino. Perhaps I will add some function to control your curtains too
CE-Designs.net Last edited by Corpius; 16th October 2012 at 08:50 PM. |
#29 | |
#30 |
I have the code. I will ask linux-works if it is ok to use/share his code.
Edit: the code is made for this project but he has used it in many systems. http://www.amb.org/audio/lcduino1/ http://www.netstuff.org/audio/ Last edited by gwikse; 16th October 2012 at 09:16 PM. |
| ES9018 - I2C interface | vt4c | Digital Line Level | 0 | 4th August 2012 01:12 AM |
| Samsung 1602VFD For CDROM Controller & Remote Volume Controller | slowgay | Swap Meet | 2 | 22nd November 2008 02:44 PM |
| I2C controller for Audio DSP | elnec | Digital Source | 6 | 15th February 2008 10:58 AM |
| I2c | Amdio | Digital Source | 9 | 29th April 2007 12:05 AM |
| I2C Controller | abid_rehan | Digital Source | 1 | 21st October 2004 10:02 AM |
