DSP Xover project (part 2) - Page 97 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Line Level
Old 18th April 2013, 03:37 PM   #961
chaparK is offline chaparK  Luxembourg
Alright, looks like the storm is behind us now
Paal has found a bug, so I have posted a fix. Version 0.0.5 is now available for download, it's only a software update (firmware unchanged).
Changes:
- Bugfix: Phase inverts in IIR mode were not always properly stored into the preset. (Thanks Paal )
- Bugfix: The 'Show Unprocessed' checkbox on the graph tab was always disabled in IIR mode.
- As requested, there's now up to 24 dB gain on EQs.
- Up to -24 dB of attenuation in IIR mode so that you don't clip if you push the EQ gain high.
- Q factor now with 2 digits after decimal point.
- Lower frequency for crossovers now down to 10 Hz (instead of 20 Hz previously). This way you can (attempt to) protect your woofer (with a high-pass) if you add a lot of bass with a 24 dB shelf for example ...
Best,
Nick
Najda DSP
Old 18th April 2013, 11:00 PM   #962
Originally Posted by kazam View Post
Bohdan,
for the third time: Let's keep this thread about Najda.
Please post about phase-linearity in a dedicated thread.
/K
Hi Kazam,
No problem.
I do apologize for the disruption.
Best Regards,
Bohdan
Old 20th April 2013, 01:43 AM   #963
Shaun is offline Shaun  South Africa
Shaun's Avatar
Originally Posted by Speedysteve7 View Post
Recently I have played two setups against each other:
1. Correction on the mid horn JBL2482 compression drivers
2. No correction.
In A/B test and blind tests (helper changing the setups with me having no idea what the starting point is), I clearly prefer them without any correction...
They sound is just less appealing and natural.
Now, I assume that the correction is pushing the the driver / horn combo to do work where out of their comfort zone and so it sounds less good.
Is it the way I am applying correction or just, you can't get things for nothing?
I do however like some correction on the bass channels. Perhaps it is a compression driver thing? Same thing with my upper mid Vitavox S2 drivers btw...
Have you had a look at what is happening off-axis? You may be creating peaks in the off-axis response that reach you via reflection. Also, make sure that you are not running out of headroom in Najda as a consequence of equalisation (boost).
Shaun Onverwacht
|||||||||| DON'T PANIC ||||||||||
Old 21st April 2013, 01:00 PM   #964
paalj is offline paalj  Norway
There where no space for the power. Have to build another box for that.
Nick, do you have a logo?
best,
Paal
Old 21st April 2013, 01:17 PM   #965
Wow! That's very nice Paal!! Very very nice!!!
Have you also drilled the rear panel?
Something others will want to ask too: Where did you get these buttons?
For the logo, how about 'Paal Industries - Norway'?
(Power supply can remain out of the box. There's nothing wrong about that I suppose)
Najda DSP
Old 21st April 2013, 05:44 PM   #966
SAC is offline SAC  United Kingdom
Would it be worthwhile keeping the power supply separate? Usually low signal boards are best kept away power supplies, as is the case here.
Old 21st April 2013, 05:47 PM   #967
Thanks a lot.
The buttons 2 x Round Cap Power/Arrow/Set/OK Logo Tactile Push Button Switch Momentary Tact LED | eBay
Najda from behind: see attachment.
For the Logo. I'll have a look
best,
Paal
Old 21st April 2013, 07:05 PM   #968
Originally Posted by paalj View Post
Thanks a lot.
best,
Paal
Great build, Paal!
Good to see another LX521 builder as well. What are your impressions so far? Have you built the ASP? Are you running full 4-way?
I'm tempted to get those buttons myself for my build which is now getting closer.
/K
Old 21st April 2013, 09:28 PM   #969
Great build, Paal!
/K
Hi kazam,
Thanks.
I had some hours of listening today and I still have goose bumps. The soundstage is even better than Orion. With some program material the soundstage is extending behind the front wall.
The LX is not finished yet, but is playable. I am in the middle of the adjustment phase (more exactly phase adjustment )
I have not built the ASP. I am not running full 4-way, but I am following your progress in another thread. My spare amp is standing here waiting..
You could maybe ask the button supplier to make a "menu" and "mute" button?
Good luck with your build!
best,
Paal
Old 21st April 2013, 10:34 PM   #970
Paal, there was a breakthrough yesterday so I can now generate biquad coefficients that replicate all the channels of the LX521.
Next I want to include a FIR block, minimum phase of course , in anticipation of individual driver variation compensation.
DSP Xover project chaparK Digital Line Level 141 3rd July 2011 10:16 AM
Help Please for simple active Xover project dcathro Analog Line Level 4 9th September 2010 05:47 AM
Violet DSP Evolution - an Open Baffle Project cuibono Multi-Way 211 18th May 2010 02:26 AM
Software digital DSP ... Xover/filters/EQ ?? JinMTVT Digital Source 2 8th October 2004 06:02 AM
DSP card & proper xover for heathkit 859A speaker cabinet x. onasis Multi-Way 6 22nd April 2003 07:39 PM
Copyright 1999-2017 diyAudio
