Go Back   Home > Forums > Source & Line > Digital Line Level
Old 20th October 2012, 01:47 AM   #1241
iancanada's Avatar
Originally Posted by ed linssen View Post
6. Cracra
7. ryanj
Please send me an email with your apply#,ID and shipping address to me at iancanada.mail@gmail.com ,for shipping the battery management PCB.
Ian
Ian - FIFO KIT & Si570 Clock Board GBIV
http://www.diyaudio.com/forums/group...ml#post3372684
Old 20th October 2012, 03:35 AM   #1242
iancanada's Avatar
Originally Posted by ryanj View Post
Ian,
You are an exception to none, one of the most valuable members of the DIY community.
Thank you!
Thanks ryanj, my pleasure! This community brought me more than what I did. I shall say thank you to you all .
Just wish your are the diyAudio moderator, they even don't accept my article about FIFO for no reason . My friend George and me spent a lot of time on it .
Ian
Old 20th October 2012, 04:25 AM   #1243
qusp is offline qusp  Australia
is choosing a less facetious title...
qusp's Avatar
did they say they didnt accept it, or just not reply? how about you send it to Jan Didden, who is responsible for Linear Audio which has been going from strength to strength, the latest edition is packed with excellent articles from people like Walt Jung, Scott Wurcer etc. still hasnt got a PDF version, but distribution is getting wider and wider. perhaps then DIYA will accept your article =P. I'm on speaking terms with a few of the Mods, want me to see if I can get it noticed? they are all pretty busy and simply may not have had the time.
Salas might be a good person to contact about it actually
Old 20th October 2012, 08:16 AM   #1244
AR2 is offline AR2  United States
Master Burner
AR2's Avatar
I will speak with Mark - Variac at Burning Amp which is next week. Jan will be there as well.
www.burningamp.com
Old 20th October 2012, 09:22 AM   #1245
qusp's Avatar
Perfect! certainly a level of contact/influence I cant emulate; lucky you man, wish I could be there....
do you have a novelty food-stuff preparation implement you bring with you also?
Old 20th October 2012, 09:28 AM   #1246
NicMac is offline NicMac  Italy
NicMac's Avatar
Ian,
Got the isolater board thank you. Looks great - even the board is cut where the isolation occours
I will place the component order for this and the battery management board these days and I also think it is time for me to invest in a dedicated smd rework station (OT: any <200$ suggestions would be welcome by PM)
Nic
Old 20th October 2012, 12:55 PM   #1247
Ian
Received the isolator board yesterday and soldered all the components today. Connected it to FIFO and clock board, use separate batteries (2xLiFe=6.6V) for clock and FIFO. All LEDs "on" but the SPDIF input card not function. Remove the isolator board, everything fine. Voltage to the ICs on the isolator board are 3.2XXV. While still finding the fault, smoke came out from the clock board, a component next to the FIFO letters on fire!!!Looks like a capacitor.
What shall I do?
Old 20th October 2012, 01:12 PM   #1248
qusp's Avatar
did you make the necessary adjustments to the clock board to use an independent supply?
that actually looks like an inductor, but I dont have the board with me at te moment
yeah lifepo4 batteries dont exactly have a current limit.... myself i'll be testing with inline fuses unconnected to the fifo board first. i'll have a think and look over the isolator board BOM/schematic, but in the meantime can you explain how exactly you supplied power?
Old 20th October 2012, 01:18 PM   #1249
qusp's Avatar
yep, you didnt prepare the clock board
it is indeed an inductor, its L11,..the one you are supposed to remove before applying independent power....
whoops
from the clock board manual
- J5, Optional DC input, (do not use if interface with FIFO board normally)
Optional independent DC power supply input for Dual XO Clock Board. FB L11 has to be removed before use this DC
Old 20th October 2012, 01:22 PM   #1250
ggking7 is offline ggking7  United States
This is why I don't sign up for test boards. I wouldn't get past first base.
XMOS-based Asynchronous USB to I2S interface Lorien Digital Source 1715 Today 08:15 AM
exaU2I - Multi-Channel Asynchronous USB to I2S Interface exa065 exaDevices 1303 10th May 2013 05:19 PM
DAC chip selection + I2S jitter questions drwho9437 Digital Line Level 2 26th July 2010 12:50 PM
Simple FIFO to I2S CPLD, for MCU players / reclocking KOON3876 Digital Line Level 21 19th September 2008 04:00 PM
asynchronous reclocking and low jitter clocks ash_dac Digital Source 3 8th February 2005 09:22 AM
Copyright ©1999-2013 diyAudio
