Go Back   Home > Forums > Amplifiers > Class D
Old 28th January 2007, 08:07 PM   #81
zilog is offline zilog  Sweden
I have protection against undervoltage, overvoltage (both rails, ~48V) and overcurrent on both output devices.
I have used wire connections to be able to use an unbroken ground plane, hopefully this keeps inductances down compared with a broken ground plane.
Old 28th January 2007, 08:57 PM   #82
classd_fromru's Avatar
zilog,
I think that if crosspieces to make on the second layer, it not considerably will affect parasitic inductance. But it will be more beautifully and more technologically.
OVP its good! A have only OCP protection...
Old 29th January 2007, 01:21 AM   #83
rogs is offline rogs  United Kingdom
I have 3 different UcDs - a Hypex UcD 180, a Philips Demo PCB, and a home made through hole prototype.
One thing I have discovered is that for short circuit protection when the amplifiers are 'on', but with no input signal present, OVP is essential.
Obviously OCP doesn't really help in this situation, but on all 3 amplifiers the -ve supply goes crazy under short circuit conditions (it pumps more and more negative), and eventually the lower Mosfet will fail. The UcD 180 has been OK, because it has OVP, and my home made one is (mostly) OK now it has OVP, but the Philips board is well and truly dead!!
So, a big 'yes' to OVP IMHO
Old 23rd September 2011, 12:53 PM   #84
stewin is offline stewin  Kenya
hi class d from ru . wow i can,t believe i found this forum. i have made this amp using irf540n .at first it used to heat like crazy but i found the solution by changing resistor from 220r to 440r . your amp is powerful will post you pictures of my trials . i never got smd components and irfb fet because of my location will post pictures
Old 24th September 2011, 09:06 AM   #85
hi class d from ru i will upload pictures of my projects once i get hold of a camera thanks
Old 24th September 2011, 11:48 AM   #86
luka is offline luka  Slovenia
luka's Avatar
Send a message via MSN to luka
what is this? if this works some what ok...
home page @ http://www.classdaudio.co.cc @ 24/7 all year long
I FEEL SLOVENIA
Old 24th September 2011, 03:54 PM   #87
hi luka it works fine,silent and very powerful .but i haven,t reached to over +/- 54vlts because of outputfets (i didnt find any bat or 1n58xx diodes so i just used the in4148) the best i can get was irf540n and irf640 they. used to heat insanely at first but when i changed resistor from to 220R to 440R all was fine
i don't have a scope to verify it but it works fine . the fets warm when operating at high volume levels . recently i found these fets irfb23n20 i will try them with +/- 90vlts hope i am in the right track.
Old 21st December 2011, 04:07 PM   #88
dudaindc's Avatar
Did you get a hold of a camera?
Old 21st December 2011, 06:24 PM   #89
luka's Avatar
those resistors are 10x too big... you shouldn't ever need to go above 100R
I FEEL SLOVENIA
Old 30th March 2012, 10:50 PM   #90
hi class d from ru ,luka and others here is my project based on this good amp but using non smd components ,totem pole parallel outputs
http://www.diysmps.com/forums/showth...ed-help/page16
Technics Class A Bias Circuits sdman Solid State 5 1st July 2010 05:58 PM
DIY projects with pictures and measurements Phil Olson Multi-Way 11 12th September 2007 04:49 PM
M61571AFP,50W 5.1ch CLASS D mini amp projects digi01 Class D 8 8th September 2004 09:37 PM
JLH 10W Class A Amps and PSU Circuits DomKo Solid State 2 19th October 2003 09:53 AM
For people who like seeing pictures of other peoples "projects" SkinnyBoy Everything Else 48 5th January 2003 11:38 PM
Page generated in 0.11081 seconds (78.25% PHP - 21.75% MySQL) with 11 queries
