Lepai T-Amp with TA2020 - Page 49 - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 27th August 2009, 07:22 PM   #481
Even with a 12V 4A power supply ? ( monitor power supply)
Old 27th August 2009, 07:52 PM   #482
I have a "CLAC" when I turn on the amp, do you have a solution ?
thanks
Old 28th August 2009, 11:06 AM   #483
Can I remove the diode after the self ?
thanks
Old 28th August 2009, 04:11 PM   #484
DrLex is offline DrLex  Belgium
Originally Posted by jkeny View Post
I'm expecting a Lepai TA2020 in about a week & was invesitigating mods. Are there further mods in addition to Dr lex's ones? Can anyone give a link to the dc offset correction mod schematic? I have some 10uh toroid inductors which I intend to try - is this the correct value?
10uH is the correct value, if the toroids can handle 3A then they're right.
Here's the DC offset correction for one channel: http://www.diyaudio.com/forums/showp...&postcount=465
For the other channel, use pins 12, 13 instead of 9, 10.
Either bypassing the tone control section or correcting it is also highly recommended. As djnemesi and col already figured out, the tone control is a 'James' Baxandall variation. From simulations it appears the component values that are installed as well as the ones printed on the PCB, are both horrible. With both controls set to neutral, the frequency response is nowhere near flat, it has a huge bump in the midtones. And to top it off, the components are cheap and inaccurate.
The first attached image shows the responses for bass/treble controls set to 0, 2.5, 5 (flat), 7.5 and 10 for the values that are installed. The curves correspond reasonably to what I measured when taking some extra loss of bass into account. The second image shows curves for the printed values, not much better.
I would suggest the following replacement values (component numbers as on the webpage). This will give the much more balanced characteristics from the third image. As soon as I have the right components, I'm definitely going to do this fix:
R1 (installed 10k, marked 15k): 20k
R3 (installed 1k5, marked 1k): 2k2
R4 (installed 1k, marked 1k5): 10k
C1 (installed 10n, marked 472): 5.6n
C2 (installed 47n, marked 393): 56n
C3 (installed and marked 10n/103 near bass pot): 1n
C4 (installed and marked 10n/103 near treble pot): 10n
There is an additional resistor not in the original James schematic at the treble potmeter (installed somewhere around 300Ω, marked 100). What this one does, is for some reason preventing that the treble control can be set all the way to 0% or 100%. It can be safely replaced by wire links or by any other small value (the marked 100Ω is OK).
Use metal film resistors and your preferred type of film capacitors. Even for C4 which stays the same value you should remove the existing components and replace them by something of higher quality. You can also replace the potmeters although for my needs they are acceptable.
Old 29th August 2009, 05:15 AM   #485
msj965 is offline msj965  United States
Hello
Is there any specific watts for the resistor? what is the best one to buy.
Old 29th August 2009, 06:11 AM   #486
col is offline col  Australia
col's Avatar
DrLex, well done thats awesome!
I will have another go at the tone controls and implement the DC offset circuit when I get the chance.
I also want to replace the volume control with a stepped attenuator that I got off Ebay, It is the same size so should be a drop in replacement.
http://cgi.ebay.com.au/DACT-Type-21-...d=p3911.c0.m14
col.
http://www.minirig.org.au
Old 31st August 2009, 04:31 AM   #487
Default Hello Drlex:)
just a small Q's regarding the R & C that you put. As a newbie on elctronics do I need to change 2 pairs of the value that you mention?example R1=20k.there is one another beside of it, do i need to change that too? and One more thing on the input resistor between 2.2uf pin 9,10 do it really need to change it to 20k as marked on the pcb is 8.25 something?
Thanks,
Ann
Old 31st August 2009, 09:41 AM   #488
Thanks,
Ann
Yes, of course there are two pairs for each value, after all it's stereo. I have borrowed one of col's photos to indicate the positions of all components. I haven't checked which exactly belong to the left and right channel, so the 'a' and 'b' components don't necessarily correspond. R7 is the extra resistor at the treble control. As you can see, the 8.25 resistor is not part of the tone circuit.
Old 31st August 2009, 01:09 PM   #489
Default Thanks Drlex:)
Drlex,
Can we eliminate the pop noise on this amp?
Old 31st August 2009, 02:40 PM   #490
jkeny is offline jkeny  Ireland
Banned
Thanx Dr Lex,
Very comprehensive reply
Finally I'll search for the schematic of the Lepai so I can
- bypass the Tone controls
- wire up the mute circuit for pop control
New ta2020 pcb'S ArjenShenzhen Vendor's Bazaar 98 14th November 2012 12:39 PM
Ta2020 Bengali Class D 0 29th September 2007 06:28 AM
Eb-ta2020 opentop Class D 16 30th May 2005 08:42 AM
Copyright 1999-2017 diyAudio
